Q7 4M Hidden Gems List
The C7 A6 forum has the same list, which is an opportunity for owners to share not so obvious features of their cars. The new Q7 is quite complex, and even after reading the owner's manual I still stumble across a new feature from time to time.
A few of my favourites:
1) Dual sun visors. There is a secondary visor under the main visor, which is useful when the primary visor is deployed for use on the side window. Also, the main visor can slide to extend its range when used on the side window.
2) Fan circulates the air after the car is turned off. Press the driver's climate control "auto" button after the car is turned off. The fan continues to run for 15 (?) minutes, dependent upon battery strength. This is useful to keep the car cool in the summer and warm in the winter. Handy for a quick stop.
3) Shortcut to access the service position for the wipers. This can be accessed through the service menu as well. It positions the wipers mid-stroke and is used for replacing or cleaning the wipers. It is also useful in icy conditions so the wipers can be lifted off the windshield so the wipers don't freeze to the windshield. After the car is turned off, hold down the wiper switch in the 1x position.
Any other "hidden" features?
Cheers.
Cheers.
- the manually retractable sunshades on the rear hatch window; who needs the clunky privacy trunk "blinds" accesory when you already have this built-into the rear hatch? Together with the tinted rear glass, can't see what's in the trunk when the trunk sunshades are deployed. Also helps keep the cabin cooler a bit. Not sure if this is standard or included only with a certain option package, but had no idea our Q7 had it until just yesterday, over a month after taking delivery lol
Don't bother looking for the battery under the hood or in the trunk. It's under the passenger seat footwell. There are connection points (for jump starting, etc) under the hood near the firewall on the passenger side.
It kinda is... when you have the AC on. There's a little "window" in the glove box that you can open/close to let cool air from the HVAC. But I'm assuming that during winter time when the HVAC puts out heat, it will become more of a warmer?
Cheers.
Cheers.
