VC Customizations
VC Customizations
So, after being pretty impressed by the Virtual Cockpit during the buying process, I'm a bit underwhelmed by it day to day. I use the map once in awhile, but most of the time I just leave it on a fuel economy screen. Is there any way to change what you see on the righthand side? I don't need to see a picture of a silver Audi (mine is white), and an oil temp reading when I have coolant temp in front of me all the time.
If you have it in that view with the gauges minimized then you're going to see the car. For that reason alone I never use that view. Maybe if the car in the VC was the same as mine I might, but I doubt it.
Coolant temp and oil temp are different, so that might be valuable to some people.
Where abouts in the Philadelphia are are you? South Jersey here.
Oil temp is extremely valuable to me. Oil temp tells you when your car is fully warmed up. Coolant temp doesn't. I baby my car till the oil temp hits 190 degrees then I drive however I need to with no worries. In other words. I get liberal with the throttle when oil temp hits 190.
SandMcars
Audi Original "S" Cars
04-30-2008 06:02 AM
nogaro*blue*you*away
03-30-2006 05:09 PM
