Evaporator drain location - 2014 A6
Old 04-26-2017, 01:50 PM
felek_pl's Avatar
Default Evaporator drain location - 2014 A6
Anyone knows where the AC evaporator drain location (under the car) is in 2014 A6? I know there is a drain tube in the center tunnel / passenger footwell area, but I am looking for the actual outlet outside of the car. I think there is a drain in the wheel well, but that is for the sunroof drainage, at least that is my understanding.
Old 04-26-2017, 03:09 PM
DB22's Avatar
Try running the a/c, then park in the driveway and check the location of the puddle of water under the car. Pretty simple huh?
Old 04-26-2017, 03:23 PM
felek_pl's Avatar
NOT if it's cold outside and not if that drain is plugged, which is why I'm asking. Make sense, huh?
Old 04-26-2017, 03:25 PM
Nakedhoof's Avatar
[popcorn][/popcorn]
Old 04-26-2017, 06:32 PM
tenspeed's Avatar
The drain usually is in the lower center of the firewall but it's an Audi and the engine compartment is packed so it could be somewhere else.
Old 04-27-2017, 02:09 AM
Mesquite77's Avatar
Service manual says from under dash one on each side of trany tunnel, near front of console on inside, through a connection to outside, so likely 2 on outside as well, one each side of tranny:
There is also a plenum drain that is under the washer fluid reservoir. Pour water in plenum to find that one.
Old 04-27-2017, 08:18 AM
DB22's Avatar
I see, may we assume that the a/c is not working and or not dehumidifying the air inside?
Old 04-27-2017, 09:17 AM
tenspeed's Avatar
cmg_r has a thread about his A6 to RS6 conversion. Post 175 has a picture of it with the engine out.I don't see any outlets. They might be under the heat shields.
https://www.audiworld.com/forums/a6-...elift-2881556/
https://www.audiworld.com/forums/a6-.../#post24881032
Old 04-27-2017, 09:18 AM
felek_pl's Avatar
Thanks everyone, I appreciate all the help and tips
jwick
11-13-2017 07:58 PM
gtab55
A6 (C7 Platform) Discussion
46
09-08-2013 04:00 AM
ghbvi
12-14-2004 10:47 AM
kgnast
NY / NJ / CT Discussion
03-20-2003 01:22 PM
Quick Reply: Evaporator drain location - 2014 A6
