Over voltage / ABS ESP Audi A6 2006
Hi guys,
Every morning when I start my car I get ESP ABS and Brakes lights flashing at me ! Anyone happened to meet those errors?
I used my vcds and got following:
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 A HW: 4F0 907 561 A
Component: ABSTANDSREGELUNGH04 0060
Revision: -------- Serial number: 00000000000000
Coding: 0051148
Shop #: WSC 02325 785 00200
VCID: 211CEC2DFDC0C1EF027-8074
3 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:20
Freeze Frame:
Temperature: 17.0°C
Voltage: 17.02 V
Bin. Bits: 01000
Hex Value: 0x0055
Hex Value: 0x0005
Speed: 0.0 km/h
Lateral Accel.: 0.99 m/s^2
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:22
Freeze Frame:
Temperature: 17.0°C
Voltage: 13.57 V
Bin. Bits: 01000
Hex Value: 0x2513
Hex Value: 0x0002
Speed: 129.6 km/h
Lateral Accel.: -4.12 m/s^2
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:22
Freeze Frame:
Temperature: 17.0°C
Voltage: 13.57 V
Bin. Bits: 01000
Hex Value: 0x2514
Hex Value: 0x0001
Speed: 129.6 km/h
Coding: 0051148
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:20
Freeze Frame:
Temperature: 17.0°C
Voltage: 17.02 V
Bin. Bits: 01000
Hex Value: 0x0055
Hex Value: 0x0005
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:22
Freeze Frame:
Temperature: 17.0°C
Voltage: 13.57 V
Bin. Bits: 01000
Hex Value: 0x2513
Hex Value: 0x0002
Speed: 129.6 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:22
Freeze Frame:
Temperature: 17.0°C
Voltage: 13.57 V
Bin. Bits: 01000
Hex Value: 0x2514
Hex Value: 0x0001
Speed: 129.6 km/h
plus this:
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 C HW: 4F0 614 517 C
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 2412E539E2D2D4C7691-8070
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:20
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0003
Hex Value: 0x22D3
Hex Value: 0x00FF
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 164798 km
Time Indication: 0
Date: 2017.04.30
Time: 07:23:20
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0003
Hex Value: 0x22D3
Hex Value: 0x00FF
2.7Tfixer
29
10-06-2021 03:18 PM
Solo786
08-18-2018 01:40 PM
