Broken Dash Piece
Broken Dash Piece
I managed to break the clip holding the left and of this long trim piece when I replaced my brake light switch. I've tried epoxy to fix it, but it doesn't seem to want to hold up to the cabin temperature when the car is in the sun. Has anyone broken this and fixed it another way? I might be searching for the wrong part name, but I wasn't able to find any used ones on eBay.
4E1 853 192 H is the part number you want. Expensive if bought through Audi - check eBay.
I had the exact same problem, broke the same tab. I was able to epoxy the tab back onto the piece - maybe it's the quality of the epoxy? I also flowed the epoxy over the sides of the tab so there was plenty of epoxy material to keep the tab connected. Let it cure for 24 hours before even trying to put it back, because the tab will always be under stress.
The tab is long gone, unfortunately. I used loctite epoxy on part of the lower dash in-between the two screws that hold it into place closest to there, and it held for about a month. Thinking I'm going to just try the used parts route, since I also managed to get epoxy all over the dash piece too.
I used 3M VHB tape. VHB = Very High Bucks Bond. High $ but incredibly strong, has a bit of foam-like cushion between the double-stick. I guess I could send you a piece.
Also I've got an extra trim piece like the one pictured; gotta go see if it's intact. I might give it to ya for postage; you seem like a righteous dude on here.
Tom
PS Trade ya for a LOBSTAH!
My favorite food.
Tom
My favorite food.
Tom
My favorite food.
Tom
My favorite food.
If you have an extra one that's kicking around, I'd be glad to take it off your hands. I decided on the replacement route since the epoxy residue on the current one is making my eye twitch.
Should I send the lobstah dead or alive?
Would anyone happen to have a picture of how the piece connects at the end that I took a picture of? I made a mess with the epoxy in there, and I think that a piece of the kick panel is broken in addition to the trim piece. I'd like to replace it, but if the piece that it connects to is broke as well I might as well just find a stronger epoxy.
Have you pulled it off? It sound like not.
Guessing that you didn't, there is a screw back behind there that holds the lower knee pad trim to the dash. Same as the left side of the column where there is another one. I get sense people just don't realize that screw is on the right side. Bentley has it--how I first got familiar w/ doing it. In turn you have to take that aluminum trim off to remove the screw for dropping lower knee panel. No way around it, and the trim is oh so fragile to pull, especially around the switch assembly. Or rather, the switch assembly mounts to the trim strip are really small and fragile.
The screw is not small or minor--those two screws (plus the ones behind side panel cover for fuses) carry most all the weight on the knee panel, and the one on the right more since it is not backed up by the screws under the side panel cover. The airbag under there adds some weight to the panel assembly being held up by the screws.
A guess is what you have is the tab is now snapped off the knee panel and sort of jammed in there holding the aluminum strip out. I would pull strip to examine. Expect the real repair is in the lower knee panel, or that you may want to get another one if available from a junk yard/eBay used in your trim color. If pics still needed, next time we drop the panel again for my W12 air suspension guesses I can take a few. May not be for another week plus though.
