Brake warning light come on
Old 05-23-2017, 01:29 AM
MBQ
MBQ's Avatar
Default Brake warning light come on
2014 A8L 3.0L TDI at 51k miles here. The brake warning light just came on recently. And there is this "replace brake pads!" or something like it flashing.
If it's the issue, what vendor you recommend to use for the brake pads? Should I replace the breaking fluid at the same time? What's the best option for it? I have hired an independent local mechanic to do the job, by the way.
Much appreciate it!
Old 05-23-2017, 03:36 AM
Jack88's Avatar
Here is the most reasonably priced source of OEM products I know. I am assuming you are North American like most forum members, if not it would be good to add your country to your profile so advice can be tailored to your market. EBC makes pads that are also well regarded. Check your rotor thickness, Audi likes to replace them every brake job but this isn't often necessary.
Old 05-23-2017, 06:12 PM
MBQ
MBQ's Avatar
I added my profile and thanks!
Old 05-24-2017, 08:12 AM
the_duke's Avatar
These guys are actually cheaper assuming that part# is correct.
https://www.audionlineparts.com/oe-audi/4h0698151n
Old 05-24-2017, 09:28 AM
SloopJohnB@mac.com's Avatar
Default Best bet is just use OEM pads, flush brake fluid
Much appreciate it!
annually and certainly when you replace pads. Usually front pads get replaced 2X rear pads, but on most Audis I've had I've found the rears get replaced fairly often because they're relatively small pads and the ABS/traction control gives them a workout.
Old 05-24-2017, 09:53 AM
Allzwell's Avatar
Who are you using for the work in Houston?
Old 05-29-2017, 04:22 PM
MBQ
MBQ's Avatar
I have a private friend who did this.
All pads/sensors for around $170. Labor $140.
Meskeetdog
10-11-2007 09:56 AM
kgardnez
03-11-2007 03:14 PM
2001SilverS4
04-17-2004 01:30 PM
Gordie
Misc. Models Discussion
9
02-11-2001 01:48 PM
audimoose
08-14-2000 04:05 PM
Quick Reply: Brake warning light come on
