RPM needle bounce
RPM needle bounce
Been having this problem for awhile. While driving, the RPM needle will bounce about 100-200 rpms however the engine is not changing rpms. Sometimes more noticeable at a lower speed, 34-45 mph. It can also be duplicated while parked and raising the rpms to 2000-2500 rpms.
I've used vcds to plot the rpms, and it's rock steady +-20rpms.
I checked the torque converter using vcds and it's acting as it should, and wasn't slipping.
Could the cluster be bad?
2008 A8 Base. 143,000 miles.
Check the fluid level in your transmission. It's a bit of a pain, but I have seen this symptom on a car that turned out to have a slow leak from the pan gasket. Any issues shifting?
Transmission is silky smooth. however; a couple mornings this past winter (32 degrees F), just during the first block, when I let off the gas, the car was jerky. After that, it was smooth. I'll check the fluid level.
Looks like I just get the transmission fluid up to temp, then fill it from underneath?
I have replaced the RPM sensor, thinking that was the problem. It did not fix my issue. But at least I have a new one in there! I also replaced the low pressure fuel pump, that didn't help.
So, the problem Is not a real one? Just the tachometer is displaying incorrectly? I would find the tach wiring diagram, find out where it get the rpm from, find an old tach meter or a cheap tach, hook it up, then you would know if the rom generator is flaky or the tach instead of throwing parts at it, you may screw up the engine in the process of replacing unnecessary parts.
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Net, seems like the conclusion is back to flaky tach gauge. Especially w/ RPM sensor changed out--assuming that OP means the crank position sensor. Presumably that is what VCDS is reading, let alone the ECU that dives smooth running (old not) to begin with.
When I experienced a 100-200 rpm fluctuation in a D3, you couldn't feel or hear the change. It wasn't the gauge, as topping off the transmission fluid after replacing the leaky gasket(and filter because why not,) solved the issue. I figured it was something about slightly low fluid levels interfered with the operation of the torque converter.
