Blind Spot Warning
Blind Spot Warning
Anyone else find the lights to be a little too cautious? On my old Cadillac SRX, the lights would do exactly what their name intends -- alert me if a car was in my blind spot. The A4 blind spot lights seem to light up when a car in a lane I want to shift to is three lengths behind me (rough estimate). Am I using them wrong? Does anyone else find this to be true? Thanks in advance for any thoughts on the subject...
They will turn on dim to tell you that there is a car, after a while you won't see the dim yellow light in the mirror anymore unless you look out for it. But if you turn on the signal they will flash bright if the car is too close. That's what's makes you reconsider changing the lane and is the real warning function.
I think it also depends a lot on how fast the approaching car is going compared to how fast your car is moving. For example, a car moving 80 mph in an adjacent lane compared to your 60 mph will be along side your car a lot quicker than if the other car is going 65 mph.
festball (07-09-2020)
Thanks so much for this. So you're saying they come on solid (though dim) if there's a car in the vicinity and the bright blinking is the true warning? I do remember seeing something along these lines in the manual, but it wasn't super clear and there was a lot to read I don't need any kind of indication that there's a car in the other lane way behind me, just a light if there's a car in my blind spot. That's how my two previous cars did it. Anyway... thanks again!
I guess, but I think it complicates it too much, though I suppose I'll get used to it. I can see a car, even if it's coming fast, if it's not in the blind spot. I just need one indicator -- is there a car in my blind spot? Then alert me. Otherwise, don't light up. Just my two cents.
The blind spot indicator can be a little disorienting in situations when you are switching lanes and it is picking up a car two lanes over. You think it's clear, you start merging and the light goes off because there's a car a whole lane over.
