Another MMI thread...with VCDS results...assistance desperately needed
Hello everyone, yes I know, another MMI thread…yes I’ve done research, yes I’ve watched all the youtube videos, yes I’ve purchased the bypass optical ring, yes I have VCDS, and I’m still stumped
Really need your help to figure this out as its driving me nuts!
When I purchased my a8, the MMI was not working, I purchased knowing that, so its not a surprise in any way, but now many months later, id really like to get it fixed as I’m missing having music and all the other setting I can mess wth on the MMI system.
So heres my story, my screen stays open at all times, the boot screen will come on only when I press whatever button, it will boot, then turn back off after about 15 seconds or so, I’ve tried the 3 button reset more times then I can remember now.
Weirdest part is after I had purchased the car without it working, one day it all randomly started working! Screen would open and close as needed, the entire system worked from the suspension setting, to nav, music, radio and everything! It worked for about 3-4 hours, then stopped again
Ive done the VCDS optical test and this is what I get
With the research I’ve done, I thought Media Player 1 was the CD changer in the glove box, so I purchased the bypass ring, unplugged the power to the CD changer and plugged in the bypass tool, nothing changed still no MMI, still boots for 15 seconds then turns off, but when I install the bypass ring it says this on the optical test
I have already removed, completely taken apart and cleaned the center console switch panel, the day when it randomly worked, every button had power and worked as it should, so Im hoping this is not my issue
So after this not solving anything, I tried to bypass every module one by one, to see if maybe it was another module, the 2 behind the glovebox, and the rest in the trunk on the drivers side, every time I would unplug the power to the module and install the bypass ring, still nothing changed, so I even tried leaving the power plugged in and installing the bypass ring, and STILL nothing changed, I’ve checked every fuse in the car possible, and none of them are blown, the battery was a new battery, so I made sure it was coded to the car, and still nothing changed
Please help guys, I’m out of ideas, I don’t know what else to check anymore
Below is a copy of the vag com scan as well
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
Hello AAO,
Please clear all codes one by one, Not with the "clear all codes" function, but 1 x 1, as your scan does not match to your optical readout, as 07 shows good in optic RO, but shows "can not be reached" in the scan.
The reason I ask for you to clear all is because out of 34 modules in your scan, 29 have faults...... and being you did not post the actual scan read out of each module, we can not know what is old or current.
Just a few thoughts as I read your thread a few time to get your flow of what you have done so far, you say that you bypassed both modules behind the glove box, well one of them is the MMI control head and can not be bypassed as it is the CH itself, which would render you with nothing, also I do not understand why you would be disconnecting the power to any module when installing the optical (LIGHT) bypass ring, you are only bypassing the optic, not the power, So PLEASE clear all the faults and start over with a new scan and optical read out, I have worked on quite a few MMI systems, and the majority of them were bad MMI control heads, with only one being the stuck button problem, others have had the Bose amp as the cause of the MMI shutting down, so do the clearing and repost scan and output test, ALSO if you could post some pictures of each module in the trunk so that we may see that you are in fact bypassing the correct units.
Johnny 908-507-6357
Johnny 908-507-6357
sorry about the confusion, i cleared all the codes, then did a scan of the entire system, and did another optical scan, the optical scan did not change
heres what the system scan shows
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CN527263
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4A383ECE269CB9F0-804A
1 Fault Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0023966
Coding: 0000002
VCID: 244037D2E740BF61AD-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 214E3EC6F852AA49C6-8074
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN527263
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58B85322EB882B81F1-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:14
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234234CEE24EB859D4-8076
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0260
Revision: 00000021 Serial number: 00000000029461
Coding: 1085761
VCID: 1B320C2EDA3E80991C-804E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H01 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H01 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO30102003065A000000000505ÿ†89
Subsystem 5 - Serial number: 000505ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO30102003065A00000000
Subsystem 7 - Serial number: 65A000000000503ÿ
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 112
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
ON
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 112
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A5CD9EA8564691197-807E
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 23:01:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 23:01:31
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
2 Faults Found:
01742 - Igniter for Knee Airbag; Drivers Side (N295)
001 - Upper Limit Exceeded - MIL ON
01743 - Igniter for Knee Airbag; Pass. Side (N296)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012241
VCID: 65C66AD6ACFA86697A-8030
Component: Lenkradmodul H03 0070
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Time Indication: 0
Date: 2063.15.31
Time: 31:63:16
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0080
Revision: D13 Serial number: AUDID3CN004353
Coding: 0016203
Shop #: WSC 77824 156 411238
VCID: 5CB04F329FB0C7A1D5-8008
1 Fault Found:
02095 - Component Protection Active
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 100
Mileage: 189752 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:23
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503A020BBE
Coding: FCFE7BDD1B2B04
Shop #: WSC 23190 444 01277
VCID: 26442DDA917C4D71B3-8072
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 95
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 20:35:53
00465 - Control Module for Telephone/Telematic (J526)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 20:48:21
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:14
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 23190 444 53268
VCID: 25462AD6EC7A4669BA-8070
7 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 135
Mileage: 189941 km
Time Indication: 0
Date: 2003.06.20
Time: 13:48:04
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 135
Mileage: 189941 km
Time Indication: 0
Date: 2003.06.20
Time: 13:48:04
01769 - Sensor for Vehicle Leveling; Front Right (G289)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 119
Mileage: 190288 km
Time Indication: 0
Date: 2003.06.22
Time: 01:33:49
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000328900291
Coding: 0003989
VCID: 1D360236C42A8EA9E2-8048
2 Faults Found:
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 107
Mileage: 189820 km
Time Indication: 0
Date: 2003.06.20
Time: 21:07:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EB4453A89ACD5B1BB-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040310290025
Coding: 0065150
VCID: 275A20DE9676547988-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
3 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 95
Mileage: 185790 km
Time Indication: 0
Date: 2003.07.31
Time: 21:43:13
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Reset counter: 95
Mileage: 185790 km
Time Indication: 0
Date: 2003.07.31
Time: 21:43:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000026277
Coding: 0010111
VCID: 1E34053AC92C95B1FB-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T08AQE
4 Faults Found:
02268 - Switch to Deploy Display Unit
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 2
Reset counter: 135
Mileage: 189884 km
Time Indication: 0
Date: 2003.06.18
Time: 03:07:00
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 135
Mileage: 189884 km
Time Indication: 0
Date: 2003.06.18
Time: 03:07:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:00
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 23190 444 100765
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 246
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Voltage: 10.77 V
Count: 240
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Voltage: 10.77 V
Count: 247
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 62CC71CABDD4F1519F-8036
5 Faults Found:
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 107
Mileage: 1048568 km
Time Indication: 0
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 107
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 189896 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 189896 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 189896 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005177363
Shop #: WSC 23190 444 100819
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 320712C0WU
Coding: 303030393135313035414B56413033323037313243305755
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
VCID: 5DB6423684AACEA9A2-8008
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
Shop #: WSC 23190 444 53494
VCID: 5FCA783E8EA6DCB9B0-800A
1 Fault Found:
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Speed: 0.0 km/h
Voltage: 10.80 V
(no units): 30.0
Temperature: 30.0°C
Temperature: 38.0°C
Temperature: 28.0°C
Temperature: 33.0°C
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 190496 km
Time Indication: 0
Date: 2003.06.23
Time: 01:53:22
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3005375
Coding: 0000005
Shop #: WSC 23190 444 52533
VCID: 60C87BC2B0D8E34189-515A
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000330800033
Coding: 0001208
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
End-------------------------(Elapsed Time: 03:32)--------------------------
Coding: 0007773
1 Fault Found:
Coding: 0000002
Coding: 0007597
2 Faults Found:
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:14
Coding: 3940448
Cannot be reached
Coding: 1085761
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 112
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 112
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Coding: 0111113
Coding: 00000030
Shop #: WSC 02311
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 23:01:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 23:01:31
Cannot be reached
Cannot be reached
Coding: 0530707
2 Faults Found:
Coding: 0012241
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Time Indication: 0
Date: 2063.15.31
Time: 31:63:16
Coding: 0016203
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 100
Mileage: 189752 km
Time Indication: 0
Date: 2003.06.18
Time: 00:00:23
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 95
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 20:35:53
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 191699 km
Time Indication: 0
Date: 2003.07.04
Time: 20:48:21
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:14
Coding: 0015510
7 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 135
Mileage: 189941 km
Time Indication: 0
Date: 2003.06.20
Time: 13:48:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 135
Mileage: 189941 km
Time Indication: 0
Date: 2003.06.20
Time: 13:48:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 119
Mileage: 190288 km
Time Indication: 0
Date: 2003.06.22
Time: 01:33:49
Coding: 4071522
Cannot be reached
Coding: 0003989
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 107
Mileage: 189820 km
Time Indication: 0
Date: 2003.06.20
Time: 21:07:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Coding: 0065150
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 95
Mileage: 185790 km
Time Indication: 0
Date: 2003.07.31
Time: 21:43:13
Freeze Frame:
Fault Priority: 3
Reset counter: 95
Mileage: 185790 km
Time Indication: 0
Date: 2003.07.31
Time: 21:43:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Cannot be reached
Coding: 0010111
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 135
Mileage: 189884 km
Time Indication: 0
Date: 2003.06.18
Time: 03:07:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 135
Mileage: 189884 km
Time Indication: 0
Date: 2003.06.18
Time: 03:07:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Revision: AV1C1010
Coding: 0000532
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 246
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Voltage: 10.77 V
Count: 240
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Voltage: 10.77 V
Count: 247
Coding: 0000001
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 107
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 107
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 189896 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 189896 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 189896 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Address 56: Radio
Cannot be reached
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Coding: 0212127
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Freeze Frame:
Speed: 0.0 km/h
Voltage: 10.80 V
(no units): 30.0
Temperature: 30.0°C
Temperature: 38.0°C
Temperature: 28.0°C
Temperature: 33.0°C
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 190496 km
Time Indication: 0
Date: 2003.06.23
Time: 01:53:22
Coding: 0000005
1 Fault Found:
Coding: 0001208
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 189888 km
Time Indication: 0
Date: 2003.06.19
Time: 01:17:15
Hello,
I take it that you did not reset the clock, and date as it shows the year 2003, ALSO it looks as you did not clear all the codes one by one in each module after you started disconnecting said modules, as the fault dates are June 17th,18, 19th, and the 20th, along with some from today July 4th, you MUST clear all the past codes that most likely resulted from you unplugging things in June.
See this thread starting at post # 45 for clearing each fault individually.
https://www.audiworld.com/forums/a8-...2905353/page5/
What you have to realize is that the MOST bus is a ring. In other words, a failure anywhere will cause all the components on the ring to fail. What you have to do is the bypass each item individually. I would start with the amplifier, then the satellite radio, etc.
Giovanni thanks for the thread, will reset each one when I get a chance
richard - I realize that, I've already done that, bypassed each module one by one and nothing changed
i noticed one of the modules says "protection active" or something like that, could that also be my problem? Can I reset a protection on a module?
As far as the CP=component protection, no you yourself car not remove it with any tool, such as RT, but some online can, or you can take it to the dealer for about $120-$150 to have it removed by way of hooking up to the Mother Ship, BUT at this time I do not think that #17 instrument cluster with CP being "active" is your problem as it shows intermittent, which is odd, but again if the vehicle is running and the instrument cluster is functioning fully, then I see no problem there, I have my brand new from dealer Can-Bus module in CP since the day I installed it and it works fully, just a note, the dealer parts dept. nor the service tech could explain how a new in box item had CP active, But back to you, I would clear all the faults when you have time, also make sure that you plugged everything back in correctly, then do a new scan and optical/electrical test and post them, what DOES bother me is that you said that you already did the optic bypass one at a time, if that IS the case and and you did that procedure correctly with the power plugs all plugged in, then I am going to go with you needing a new or used MMI CH, if you buy used off EBay or anywhere used, then you have a 50/50 chance of the used replacement MMI CH going into CP, which will require a trip to the dealer as stated above, or others on here know of a guy who can do it online with access to your laptop and vehicle, in case you did not know, when the MMI CH goes into CP, all the functions of MMI will work, but you will have no sound, the MMI screen will show the speaker muted, OR you could get lucky and get a used MMI CH from Europe at A8Parts (CARL) which I did and had no CP, and did not go into CP when I installed it, but I did have to flash it from Euro to NA.
You have my number if you need me to walk you though anything, I am in Jersey so time of day is a factor.
I did not see anywhere if you stated what year your A8 is, so here is a MMI CH that will fit 2004-10, as it has the green FBAS connector for video input such as RVC if you have a 07-09, or you retrofit RVC into a 04-06 model.
2007- 2010 Audi A8 A8l D3 MMI Interface Control Module 4e0035729a | eBay
