Top View Camera Glitch?
Hey Everyone,
I am wondering if anyone else is dealing with this same minor headache as me.
I have an S4 prestige with the parking system plus..
When parking assist is on (backing up in reverse or by manual activation), I have it set to display the camera on the left of the screen and the top view on the right.
But for some reason after a restart it will continue to go back to the original set up of: Camera in the left and only optical parking sensor view on the right.
It seams the top view glitches back to the usual optical sensor view. I have gone into the settings and keep changing it to show top view camera view but it keeps glitching back after the car restarts.
I was wondering if anyone else has notified this. Is it a bug? Or maybe just that Audi doesn't want us to enjoy the 360 top view by default and have to continue to select it.
I thought it was the SQ5's design (software). The S4 works always showing the "around view" or top-view on the right and the front or rear camera on the left.
Must be a setting somewhere.
My S4 works like yours, John. My wife's top-view has to be "turned on" every time. If you don't it defaults to back or front camera on the left side of the screen and "parktronic" sensor array display (but not including the stitched view) on the right.
There is no particular pattern. And it appears to revert back at random.
Once the setting is selected in the MMI it should stay selected. I guess check with the dealer if they have a software build date later than yours and they should be able to update and fix this.
Crossing my fingers that new phone will fix everything including dropped calls (about which there are a ton of posts).
I changed the setting FROM graphic to camera and all's been well. I'm sorry I can't get to the car this minute, but the fix (assuming it is NOT the phone) is in the owner's manual.
#1 Start the car
#2 Put the gear selector in R
#3 When the backup camera comes on move the wheel in the middle of the console to the right (do NOT turn the wheel)
#4 A new screen will appear
#5 Item number 3 is a drop down, it allows you to select Camera or Graphic
Select Camera.
Move the selector (rotating the wheel) to END SYSTEM.
Take the car out of reverse.
Change the radio to another station -- it doesn't matter which, the back up camera screen will disappear.
Shift the car back in R, the camera view will show on the right ONE THIRD of the screen (it will be the top view).
I just sat in the car to write this -- I have tried it three times, switching to camera, then graphic then back to camera.
It sticks.
I love doing this kind of thing -- but it IS in the owner's manual.
Select Camera.
It sticks.
