Octane Rating
It's recommended by the engine mfr.: 91 AKI or better
At first I was using high octane but eventually went to the regular. Then at some point there was carbon build up and the dealer had to clean it out. Luckily I had AudiCare which took care of it.
This was with my '10 Q5. I think if you had an SQ5 I would stick with the higher octane because the engine is tuned more to expect that.
When my engine light came on and I got it serviced I was surprised they told me the cause was due to the grade of the gas which has various levels of contaminants that caused the build up versus burning off. Your Audi dealer should have a list of recommended gas stations to use for your area.
At the minimum I would consider using at least an 89 Octane versus 87 to avoid the issues I had. Also assuming you have a Q5 and not an SQ5.
The list of gas stations is important too because getting 89 octane gas from a Costco versus BP Oil versus your Local Supermarket will still have varying degrees of pollutants.
Audi recommends
Home | Top Tier Gas
Home | Top Tier Gas
