Car don't start, parkingbrake, esc fault
A couple of days ago, my car started to give me error codes on startup / ignition on, it complains in the display on parking brake malfunction and stabilisation control esc fault, and when I search with the OBDeleven I get many error codes almost all pointing to ECM, so I guess somewhere there lures my problem..
When the error occurs and all codes are given, the car does not start, I can delete all the error codes and after switching off and on ignition, then the car starts and everything works properly.
What is done?
Battery checked, 12.8V standby, 14.4V when driving, Charged to 13.00V, pending between 9-10V at startup.
Error codes cleared several times, can go anywhere between 1-4 starts between times the car gives error codes.
Cleaned MAF sensor and Intake
Cleaned connectors at ECU side
Cleaned connectors at parking brake module
Anyone who can check the error codes below and maybe give me a direction to go on next?
Here is a clip on the messenges I get:
Codes:
OBDeleven data log
Date: 2017-07-16 18:59
Car: Audi A4
Year: 2013
Body type: Avant
Engine: CGLC 130 kW (177 HP) 2 l
Mileage: 120410 KM
01 Engine
System description: R4 2,0L EDC
Software number: 03L906018JH
Software version: 2903
Hardware number: 03L906018JL
Hardware version: X25
ODX name: EV_ECM20TDI01103L906018JH
ODX version: 003003
Long coding: 12194012243601080000
Trouble codes:
No trouble codes found
03 Brakes
System description: ESP8 quattro
Software number: 8K0907379CK
Software version: 0100
Hardware number: 8K0907379CK
Hardware version: H09
Serial number: --------------
Long coding: 18D54C
Trouble codes:
00473 - Electronic parking brake control module -J540 Please read DTC
static
01314 - Engine control module (ECM) No signal/communication
Intermittent
04 Steering Angle Sender
05 Kessy
System description: BCM2 2.0
Software number: 8K0907064GE
Software version: 0621
Hardware number: 8K0907064FE
Hardware version: H11
Long coding: 03A24000000000000000
Subsystems:
System description: FBSAUDIB8 IDG
Software number: 8K0959754H
Software version: 0083
Hardware version: H71
Serial number: 0812000102257005
System description: J764 ELV MLB
Software number: 8K0905852E
Software version: 0046
Hardware version: H40
Serial number: 2312000113741001
Trouble codes:
01330 - Comfort system central control module Please read DTC
Intermittent
08 Air Conditioning
System description: KLIMA 1 ZONE
Software number: 8K1820043AB
Software version: 0122
Hardware number: 8K1820043AB
Hardware version: H02
Serial number: 01040620121587
Long coding: 342002E000
Trouble codes:
01314 - Engine control module (ECM) Implausible signal
Intermittent
Intermittent
09 Central Electrics
System description: BCM1 1.0
Software number: 8K0907063DH
Software version: 0103
Hardware number: 8K0907063DH
Hardware version: H16
Serial number: 00000431637302
Long coding: 2600C0148034AFC00081400300001D0D4F1C26082609020100 0004000400030100000020000000
Subsystems:
System description: WWS 310512
Software number: 8K1955119A
Software version: 0070
Hardware version: H07
Serial number: SWF12050315193
Long coding: 00FD11
System description: G397_RLFS
Software number: 8U0955559B
Software version: 0002
Hardware version: H06
Serial number: 20311182
Long coding: 02005D
System description: E1 - LDS
Software number: 8K0941531AS
Software version: 0031
Hardware version: H03
Serial number: 00000000002205120259
System description: Humidity_Sens
Software number: 4G0907658A
Serial number: B328CF26000000000001
Trouble codes:
Intermittent
15 Airbag
System description: AirbagVW-AU10
Software number: 8K0959655N
Software version: 0610
Hardware number: 8K0959655N
Hardware version: H45
Serial number: 003KFD93BXEZ
ODX name: EV_AirbaECUVWAUDI010
ODX version: 003010
Long coding: 30514435363030303030554A304C384B3053
Trouble codes:
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 8R0953568Q
Software version: 0171
Hardware number: 8R0953568Q
Serial number: 20120605001296
Long coding: 000017
Subsystems:
System description: E221 - MFL
Software version: 0003
Trouble codes:
17 Dash Board
System description: KOMBIINSTR.
Software number: 8K0920931J
Software version: 0553
Hardware number: 8K0920931J
Hardware version: H35
Serial number: RBJ64CZ5D
Long coding: 138D110002010008010000
Trouble codes:
Intermittent
19 Gateway
System description: GW-BEM 5CAN
Software number: 8R0907468F
Software version: 0051
Hardware number: 8R0907468A
Serial number: 2441V125098297
Long coding: 80CF07FF00
Subsystems:
System description: J367-BDMHella
Software number: 8T0915181
Software version: 8041
Serial number: 9623957401
System description: J532_DCDCStab
Software number: 8K0959663B
Software version: 0006
Hardware version: H05
Serial number: 12144002615021200410
Trouble codes:
01312 - Drive train data bus No signal/communication
Intermittent
Intermittent
42 Door Electronics Driver Side
System description: TSG FA
Software number: 8K0959793R
Software version: 0506
Hardware number: 8K0959793P
Serial number: 0000031138503
Long coding: 011C02204000410001
Trouble codes:
44 Steering Assistance
System description: RCEPS
Software number: 8K0909144F
Software version: 0507
Hardware number: 8K0909144B
Hardware version: H36
Serial number: 0012576288
ODX name: EV_RCEPSAU48X
ODX version: 008014
Long coding: 100000000001
Trouble codes:
U111100 - Function limitation due to missing message
Intermittent
46 Central Module Comfort System
Serial number: 0177753147
Long coding: 013E062020B900408020023680000000
Subsystems:
System description: DWA-Sensor
Software number: 8K0951177
Software version: 0040
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
Trouble codes:
Intermittent
Intermittent
52 Door Electronics Passenger Side
System description: TSG BF
Software number: 8K0959792R
Hardware number: 8K0959792P
Serial number: 0000031142528
Long coding: 011C02204C00410001
Trouble codes:
53 Parking Brake
System description: EPB-4
Software number: 8K0907801K
Hardware number: 8K0907801J
Hardware version: H01
Serial number: 10000000055860
ODX name: EV_ParkiBrake
ODX version: 001027
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
C10BF15 - Clutch position sensor Open circuit/short circuit to B+
Intermittent
56 Radio
System description: Concert3
Software number: 8R1035186F
Software version: 0460
Hardware number: 8R1035186F
Hardware version: H08
Serial number: AUZ5Z6L1751795
Long coding: 0500048204028500815B070000
Subsystems:
System description: Display
Software number: 8T0919603G
Trouble codes:
static
62 Door Electronics Rear Left
System description: TSG HL
Software number: 8K0959795G
Hardware number: 8K0959795D
Serial number: 0000031265411
Long coding: 010C02204000210001
Trouble codes:
69 Trailer Function
System description: Anhaenger
Software number: 8K0907383E
Hardware number: 8K0907383E
Serial number: 00000177379123
Long coding: 010D000000000000
Trouble codes:
Intermittent
72 Door Electronics Rear Right
System description: TSG HR
Serial number: 0000031265435
Trouble codes:
77 Telephone
System description: FSE_256x BT H45
Software version: 0660
Hardware number: 8T0862335F
Serial number: 00000005504722
Coding: 0010390
Trouble codes:
What is done?
Codes:
OBDeleven data log
Car: Audi A4
Year: 2013
Body type: Avant
Mileage: 120410 KM
01 Engine
ODX version: 003003
Trouble codes:
03 Brakes
Long coding: 18D54C
Trouble codes:
static
Intermittent
05 Kessy
Subsystems:
Trouble codes:
Intermittent
08 Air Conditioning
Trouble codes:
Intermittent
Intermittent
Subsystems:
Long coding: 00FD11
Long coding: 02005D
Trouble codes:
Intermittent
15 Airbag
ODX version: 003010
Trouble codes:
Long coding: 000017
Subsystems:
Trouble codes:
17 Dash Board
Trouble codes:
Intermittent
19 Gateway
Subsystems:
Trouble codes:
Intermittent
Intermittent
Trouble codes:
ODX version: 008014
Trouble codes:
Intermittent
Subsystems:
Trouble codes:
Intermittent
Intermittent
Trouble codes:
53 Parking Brake
ODX version: 001027
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
56 Radio
Subsystems:
Trouble codes:
static
Trouble codes:
69 Trailer Function
Trouble codes:
Intermittent
Trouble codes:
77 Telephone
Coding: 0010390
Trouble codes:
Hendrik Snyman (07-01-2020)
ESC+parking brake lights is a general "something is wrong with the car". I had the same thing this morning, because I forgot to plug the MAF cable back in after changing the air filter. Seems it's too hard for the car to just say "MAF disconnected".
OBD11 doesn't provide more detail? There's usually a subcode with what's actually wrong, as well as a freeze frame, when I get errors in VCDS. Such as:
02283 - Video Connection to Output [End Unit]
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 244090 km
Time Indication: 0
Date: 2017.07.25
Time: 09:54:42
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Maybe a loose connector block somewhere. I have the issue with short to ground for the keyless antenna in the back left door. But the wire is not direct from the antenna to the comfort control module. They both connect at a block in the bottom of the left B pillar.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 244090 km
Time Indication: 0
Date: 2017.07.25
Time: 09:54:42
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Such as:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 244090 km
Time Indication: 0
Date: 2017.07.25
Time: 09:54:42
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 244090 km
Time Indication: 0
Date: 2017.07.25
Time: 09:54:42
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Trouble codes:
Intermittent
Then you need to search for the code and then you get:
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Engine Control Module recently flashed or re-mapped
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
Chasing down an electrical issue in a german car. All I can say is good luck. :-)
Audi a4
What is done?
https://www.youtube.com/watch?v=p12WHQIGJhI
Codes:
OBDeleven data log
Car: Audi A4
Year: 2013
Body type: Avant
Mileage: 120410 KM
01 Engine
ODX version: 003003
Trouble codes:
03 Brakes
Long coding: 18D54C
Trouble codes:
static
Intermittent
05 Kessy
Subsystems:
Trouble codes:
Intermittent
08 Air Conditioning
Trouble codes:
Intermittent
Intermittent
Subsystems:
Long coding: 00FD11
Long coding: 02005D
Trouble codes:
Intermittent
15 Airbag
ODX version: 003010
Trouble codes:
Long coding: 000017
Subsystems:
Trouble codes:
17 Dash Board
Trouble codes:
Intermittent
19 Gateway
Subsystems:
Trouble codes:
Intermittent
Intermittent
Trouble codes:
ODX version: 008014
Trouble codes:
Intermittent
Subsystems:
Trouble codes:
Intermittent
Intermittent
Trouble codes:
53 Parking Brake
ODX version: 001027
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
56 Radio
Subsystems:
Trouble codes:
static
Trouble codes:
69 Trailer Function
Trouble codes:
Intermittent
Trouble codes:
77 Telephone
Coding: 0010390
Trouble codes:
What is done?
Codes:
OBDeleven data log
Car: Audi A4
Year: 2013
Body type: Avant
Mileage: 120410 KM
01 Engine
ODX version: 003003
Trouble codes:
03 Brakes
Long coding: 18D54C
Trouble codes:
static
Intermittent
05 Kessy
Subsystems:
Trouble codes:
Intermittent
08 Air Conditioning
Trouble codes:
Intermittent
Intermittent
Subsystems:
Long coding: 00FD11
Long coding: 02005D
Trouble codes:
Intermittent
15 Airbag
ODX version: 003010
Trouble codes:
Long coding: 000017
Subsystems:
Trouble codes:
17 Dash Board
Trouble codes:
Intermittent
19 Gateway
Subsystems:
Trouble codes:
Intermittent
Intermittent
Trouble codes:
ODX version: 008014
Trouble codes:
Intermittent
Subsystems:
Trouble codes:
Intermittent
Intermittent
Trouble codes:
53 Parking Brake
ODX version: 001027
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
56 Radio
Subsystems:
Trouble codes:
static
Trouble codes:
69 Trailer Function
Trouble codes:
Intermittent
Trouble codes:
77 Telephone
Coding: 0010390
Trouble codes:
Jontelito
A4 (B8 Platform) Discussion
07-21-2017 01:03 PM
Jontelito
07-19-2017 03:15 PM
Jontelito
07-19-2017 11:47 AM
DAS4
05-29-2012 06:27 AM
$teady$upreme
08-30-2004 11:48 PM
