Traffic Jam Assistant Coding - OBDEleven or VCDS?
Thanks to everyone for the posts on enabling lane keep assist; I used my new obdeleven and enabled it on my 2018 Q5 and it worked great!
Wondering - does anyone know if we can enable "traffic jam assist" that basically enables the Lane keep assist with cruise on at low speeds?
Thanks!
Thanks!
Hey amorak, since you said you used the OBDEleven on your Q5, I'm assuming it worked ok? Their website doesn't have the 2018's on the "supported" list yet. I'd like to get one and play around with it as well.
My OBDEleven read my VIN & added it to my "Garage" as a 2018 Q5 with no problem.
Thanks!
Thanks!
The first requirement for TJA to become active is that Adaptive Cruise Control must be turned on. There are also other requirements of which the manual is not very clear, but it concerns other vehicles to be present in front and next to the vehicle. I've been unable to formulate a set of rules for myself as to when TJA becomes active as far as the latter aspect is concerned, but it seems to me that it either requires a vehicle in front and vehicles on each side, or a vehicle in front and a single vehicle on either the left of the right, if the road markings (lines) are very distinct.
It seems that TJA works for longer periods than Active Lane Assist and is less concerned (than ALA) about a lack of steering wheel input.
It works fairly well in stop/start traffic on the freeway, but it is definitely not a matter of the vehicle driving itself. One has to stay alert to what is going on around the vehicle to be able to take over if matters become too complicated for the system to deal with.
This guy provides a good demonstration of how the system works:
But I'm not at all sure of what I'm saying. I have not seen anyone who managed to code Traffic Jam Assist, although Kufatec sells a module which when plugged into your OBD port, does the coding. So they must have figured it out. https://www.kufatec.de/shop/en/audi/...ist-audi-q5-fy According to their website, these are the requirements:
Note:
Only suitable for vehicles with QK1
After installation the vehicle has to be coded
I've not been able to figure out what QK1 is. The coding required is simply the basic settings of the steering wheel which need to be done and which any dealer will be able to do.
Thanks!
Thanks!
You have indicated you've been successful in enabling lane keep assist on your '18 Q5 using OBDeleven. That's great news!
I have a question... the '18 Q5 owner's manual (p. 118-120) shows/explains that vehicles equipped with active lane assist have a push button on the end of the turn signal lever. The turn signal lever in my Q5 has no such push button. When you enabled active lane assist did you replace your original turn signal lever with a new one having a push button?
Also.. are you located in North America, or elsewhere?
Thanks
/R
