2014 Q7 TDI Fuel Filter Change
If you've found this thread, your searching like I did. Lucky for you I've done it and taken a few photo's!
Step 1: I would recommend picking up some supplies you might or might not have.
I used:
-Audi/VW Fuel Filter - Hengst 8K0127400A (Amazon was out of stock)
(Auto paper towels from the local Sams Club)
-1 Large and 1 small pair of pliers
-Small paint cup/ bucket to catch the used filters fuel dump.
- Vagcom Hex-V2 Cable
*Mac running, Win10 in Parallels
Step 2: prep and place a bunch of rags below each filter connection.
Step 3: Grab the set of fuel line clamps and pinch about 4 inches back from the fuel filter connection points.
Step 4: Use which ever set of pliers work and pinch the fuel line clamps and remove the line from the filter (minor fuel seepage)
Step 5: Remove the other side and then remove the filter from the area, I recommend placing it in a small paint bucket or whatever you have lying around full of paper towels. NOTICE the rubber rings that held it in place, we're going to reuse those, so go ahead and slip both of them off.
Step 6: Remove the foam rings from the new Fuel filter, and replace the the Rubber rings from the old fuel filter.
Step 7: WATCH the direction of the arrows and make sure you're connecting the filter in the right direction. The arrow should face the Passenger Compartment.
Step 8: Reattach the fuel lines and make sure the clamps are in the OE place to secure the lines to the filter nipples.
Step 9: Remove the (2) fuel line clamps.
Step 10: We're going to use VagCom (VCDS) to energize the life pump and prime the system.
Step 11: Connect up the car to your computer, smart phone and bring up Vagcom (VCDS)
Step 12: Navigate to Fuel Pump and activate the lift pump for 20-30 seconds. I did it that long, and the rig started up instantly like it always has.
That's it! Super simple.
I would recommend you write the date and mileage on the filter with a black sharpie for the future when you're wondering when you last did it.
I used:
The following 2 users liked this post by Built4Sin:
Cboogie (06-21-2020),
firstgermancar (04-14-2024)
Thanks for the write-up. It's on my list of things to do.
In your Step 12, what is the navigation path to the Fuel Pump, and how do you access the link to the lift pump command?
Did you have any problem achieving good leak proof tightness of the OE hose clamps to the new fuel filter? Any special technique needed to be sure they are secure?
TIA!
TIA!
01 Engine (menu)
-Output Tests
--Fuel Pump Electronics
Click the start button (You'll audibly hear it running)
As for the lines themselves, they're on there! I was going to change them out for worm clamps, but they seemed tight enough. After the prime, I just checked to see if anything was dripping. Looked good, I'll check it again in the future.
This is the easiest filter change I've done so far, compared of MK4 TDIs, and my BMW (under the car).
Take it easy!
-Output Tests
Take it easy!
TIA!
TIA!
Good write up. That is exactly how I did ours. Except I ran the priming procedure with VCDS twice for good measure. Probably overkill but my experience with diesel tractors and trucks made me fear an air bubble. It IS a super easy procedure compared to the old cartridge type filters.
Finished up the fuel filter replacement. No issues, Q7 started right away, I took it for a drive afterwards and all is well. I did prime for about 2 minutes (4 - 30 second intervals) using VCDS. Also, one of my pinch clamps slipped off and I had to go fishing for it. Other than that it was straight forward, thanks for the DIY write-up!
I did this replacement back in July. As mentioned, it is quite easy.
I'm curious, though.... is this the only fuel filter? I have another filter, which looks much like those for the 2L TDI (except larger), and I cannot find any sort of canister where it might be used. Parts suppliers, such as Rock Auto, list this as the fuel filter, and they list the filter we all changed as being a "fuel water separator." Any information appreciated!
Hopefully I employed the attachment function correctly. There should be two screen shots... first showing an image of the mystery fuel filter, and the second showing the nomenclature for the filter in the engine bay that we changed in this thread.
Thanks!
Thanks!
