Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Activating G meter - "Sport Displays" in Virtual Cockpit
Old 09-03-2017, 10:05 PM
arU4ic's Avatar
Default Activating G meter - "Sport Displays" in Virtual Cockpit
This worked on my 2018 with Virtual Cockpit, activating what the manual calls "Sport Displays"
Using VCDS:
17 - Instruments>Coding>Long Coding Helper>byte 10
Check the "Display 'Acceleration' " box and commit.
Attached Thumbnails Activating G meter - "Sport Displays" in Virtual Cockpit-screen-shot-2017-09-03-11.00.59-pm.png
Old 09-05-2017, 06:33 AM
Saul Davidson's Avatar
I wonder if we can activate these displays in the A3..... thoughts?
Old 09-05-2017, 10:25 AM
dcosta's Avatar
I have activated it in my A3 but it looks like the sensors are not present so the readings are always 0.
Old 09-05-2017, 08:16 PM
arU4ic's Avatar
Interesting.. I would think it would be easier to just have it in every car - why would they install the sensor in the S3 but not activate it? Not put it in an A3 at all? Hmmmmm.
Old 09-05-2017, 08:37 PM
dcosta's Avatar
I miss spoke, I do not know if the sensors are not present (they probably/are present as you can collect the data from OBD11) but the information is not being sent to the G-meter display, possibly missing some other setting that I didn't bother looking into.
Old 09-06-2017, 07:00 AM
I wish we could activate the centered "tachometer" only view like the S series has.
Old 09-06-2017, 10:25 PM
arU4ic's Avatar
That's got to be an option with a little VCDS doctoring...
Old 09-28-2017, 08:35 AM
Skynet's Avatar
Hi,
Any other code to activate the graph ?
Old 09-28-2017, 09:23 AM
arU4ic's Avatar
Originally Posted by Skynet
Hi,
Nope, that was it. Is it not working for you?
Old 12-02-2018, 10:37 AM
Waggin's Avatar
Same on my S5 Sportback. I guess there's some sensor module that's missing. The G-meter was mentioned in the owner's manual, so there may be a way to add it.
Quick Reply: Activating G meter - "Sport Displays" in Virtual Cockpit
