Winter tire packages are up on Tire Rack for 2018 A5/S5
Old 09-14-2017, 04:38 AM
joe3nyc's Avatar
Default Winter tire packages are up on Tire Rack for 2018 A5/S5
Just noticed they have wheels and tire packages for the coming winter weather for 2018 A5/S5
Old 09-14-2017, 08:09 AM
steviekallday's Avatar
perhaps a link and price would be useful?
Old 09-14-2017, 08:17 AM
NABS4's Avatar
Or just search under the year/model at tirerack.com
Old 09-14-2017, 09:28 PM
JRuby2004's Avatar
So very much a newbie question, but I read on some other threads here that there could be a concern about some wheels not clearing the brake caliper? Is that just a concern for "exotic" wheels, or is that something we need to look out for in general? I would assume that choosing a wheel with the same diameter, width, offset, and bolt pattern as the OEM wheels would be ok, but again I am new to aftermarket wheels.
I have the 19 inch wheels on my S5 sportback, and I'm going to be buying 18 inch wheels for a set of dedicated winters. Ideally I'd find something used on eBay but I don't know if I have the expertise to navigate through all the crap to find the good stuff.
Old 09-15-2017, 10:24 AM
jb606's Avatar
Its your money but 17" wheels will fit on the S5 SB. If you want to get an idea checkout tirerack. I've had good luck with them as far as finding wheels/tires that fit correctly. The big thing is try to get as close to the same overall tire diameter so your speedometer doesn't get messed up.
Old 09-15-2017, 10:27 AM
NABS4's Avatar
Yes, there are lots of considerations: Bolt pattern, hub bore, offset, caliper size... etc. Tire Rack test fits all the wheels, so if they state a wheel will fit, it will. If you're not comfortable navigating wheels, I'd stick to a larger supplier, not a random ebay supplier.
Old 09-15-2017, 10:30 AM
NABS4's Avatar
It depends on the 17" wheels, not all will.
Old 09-15-2017, 10:45 AM
jb606's Avatar
Very true!
Old 09-15-2017, 12:54 PM
Eli McCraig's Avatar
Yay! Will need a winter wheel tire set up for my new S4/5/5SB...will be picking it up in dead of winter with 19" summer tires.
Old 09-15-2017, 03:42 PM
Emerson11's Avatar
Snark!
Quick Reply: Winter tire packages are up on Tire Rack for 2018 A5/S5
