Leaving for 6 months: What should I do?
I am leaving for 6 months and won't be driving my Q5 TDI. It is parked in secured underground parking, but what should I do if anything to take care of the car for 6 months?
I don't have any nearby plug to charge the battery or anything... should I just leave everything as-is or should I remove the battery and charge (or trickle charge or whatever those things are) it at my mom's house or something (can't park whole car there)?
Don't have a car cover, but should I consider some cover option for the car? It definitely will get dusty not moving for 6 months...
Anything else to consider?
If I believed the battery was in good condition, I'd probably just add diesel fuel stabilizer in a few tanks before you depart so it's well-mixed by the time you put it away. The battery should start the car upon your return.
Remove the battery and put it on a smart trickle charger at your mom's house. Inflate your tires to the maximum pressure allowed for your specific tires. Put a tray of mouse poison on the floor of the car. A car cover would be a good idea. See if you can find one that comes with a steel cable that runs under the car and can be secured with a padlock to discourage theft of the cover. Add the appropriate amount of fuel preservative to your fuel tank and then fill the tank.
They will preserve the life of the engine and ensure that your car starts when you return to it.
How To Prep Your Car for Long-Term Storage | Edmunds
- Keep It Covered. A garage is the ideal place to store a vehicle. ...
- Clean It Up. ...
- Change the Oil. ...
- Top Off the Tank. ...
- Keep It Charged. ...
- Don't Use the Parking Brake. ...
- Prevent Flat Spots. ...
- Keep Critters Out.
Having a trusted friend or family member use (not just a short trip) the vehicle occasionally (every few weeks) is another plan.
Check with your insurance company to see if they have a reduced rate for cars which are placed in temporary storage. My company, USAA, gives a significant discount for any vehicle placed in storage for 30 days or more. Essentially they discontinue your BI, property damage, collision, etc. leaving in place your comprehensive coverage which is really all you need for a stored vehicle. Don't do this, however, if you're going to have someone drive your car periodically while you're gone as Shokhead suggested.
1. Remove the -ve pole.
2. Put a kitchen towel in the exhaust to avoid air/moisture entering.
3. Fill it up with fuel
The battery is an AGM battery, and it can sit unconnected for six months without taking any damage. If you can take it out and put it on a trickle charger, yes, that will be better, but not essential. I would suggest something like a NOCO Genius charger, which is considerably more expensive than a $20 "tender", because the $20 chargers can easily DAMAGE an AGM battery. They're just not very good at the job, the folks who make them are pretty much clerks selling boxes, with no understanding of the products and issues.
And yes, you do have to at least disconnect the battery, or the car will eat it within 2 months. There is some type of pyrotechnic disconnect fuse device on the negative cable assembly, Audi notes that should be handled with care.
When you put stabilizer in the fuel tank, you actually need to add the stabilizer, drive around for a while so it circulates through the fuel system and tank, and THEN come back to fill up the tank and park it. How long is a while? I'd give it at least 15 minutes. If you put it in a day or two before filling up, that's fine too.
Put a little extra air in the tires, inflate them to the max PSI, since they may lose a pound a month while they are sitting.
