AC Pressure Switch
AC Pressure Switch
I recharge the ac system with freon but can not feel the cold inside the car, I turn off the car and hear the pressure switch infront of the condenser leaking (actually blowing freon) but it leaks behind the connector, I move them 3 wires up and down and they leak or I losen up the switch and it stops leaking but if its to tight it leaks behind the connector. Condenser is new and ac compressor is used but works. Dont know whether the switch is bad or the connector is bad. Car does ho on econ mode and nothing turns on no even the fan or ac compressor. What shall I do?
Replace the pressure switch, mine leaked too
https://www.audiworld.com/forums/sho...2900106&page=1
Cheers,
Louis
Cheers,
Louis
Ziptar
09-07-2007 04:11 AM
Luxus Panzer
9
06-02-2004 11:45 AM
