Top View Camera Issue
There have been numerous references to this issue scattered throughout numerous threads in the Q7, A4, & Q5 forums but those of you experiencing the problem might find some useful info in this thread from the Q7 MK II forum.
https://www.audiworld.com/forums/q7-...cking-2933305/
When parking distance control is active and the forward view is displayed, the car will show a graphic view. If that's the last view shown before the MMI goes to sleep, apparently that's when the setting is overwritten.
I use it all of the time along with the parking brake. It's nice how you can put the car in gear with the parking brake engaged, then touch the gas and it'll disable itself. I use that quite often
Just to confirm with everyone I have verified if you shut the Q5 off while in Reverse; when you turn the Q5 back on the top view is on camera mode and does not default back to graphic. It will have to do until auto comes out with a software fix.
It does every so often for me. I'm used to changing back to graphic constantly. Hopefully Audi will post a fix soon
I've been careful to make sure the camera mode is the last mode displayed when putting the car into Reverse and then turn off the car. This works for me about 75% of the time. This is not a 100% work around for me.
Very useful thread. It was not until I opened a new thread on this issue did I realize that this is such a widespread problem.
Anyway, will try the workaround today.
Just to be clear, I can turn off the car when the gear is in R mode. But I still need to engage the parking brake manually, right?
