Winter Wheel Sets
Winter Wheel Sets
I will pickup my 2018 Q5 this coming weekend. The vehicle comes with the 20 inch all season tires.
However, the winter is coming very soon and I need to purchase the a set of winter wheel sets after I pickup the vehicle.
Regarding the wheels, what will be the correct hub centric size and wheel specs. and offset for the 2018 Q5? I need to pay extra for the TPMS as well for the winter wheels.
I am new to Audi and I do not have much information about the wheel specs. such as torque for wheel bolts and etc.
I see in the Audi website, they recommend to use the 17 inch winter wheel sets for the Q5. To me, the 17 inch wheels look weird to a mid-size SUV.
I am thinking about using the 18 inch winter set. is anyone here also purchase the 18 inch wheel sets and already installed on the Q5?
Can you post some pictures and let me see how they look like?
Regarding the winter tires, I am thinking using the Continental tires (have not decided which model, I think they have 2 models to choose from the tirerack website).
Thanks.
Thanks.
Good news! You don’t have to pay for TPMS as there are no sensors. The tire pressure is calculated based on rotation or something. Personally I recommend only going down one size in wheel diameter and sticking with OEM tire sizes but you’ll hear the snow freaks say 17s and 215 wide because mother Russia and stuff.
Bad news . I am from Canada, I double checked the specs., the wheels came with TPMS. I wish the air pressure calculated based on the wheels rotation.
If I downsize to 19 inch winter tires, the price are very expensive and the tire choices are very limited.
You have a Tire Pressure Monitoring System but it does not use in-wheel sensors, Audi abandoned that system a long time ago.. even in Canada.. open your wheels up and you'll find no sensors contained within but it still knows if you get a flat.
18's should provide a wide selection of affordable snow rated tires.
Build and Price > 2018 Q5 > Audi Canada
This is what it said in their website.
i will double check with the dealership next week. If there is none, I will save a lot.
18’s and 20’s here
Thanks.
Thanks.
I have two options I have chosen. My 2010 Lexus RX450 has dedicated 18 inch alloy wheels/Blizzak winter from Discount tire. (using last years Labor Day $320 discount/rebates, great opportunity but you have to be fast because they run out fast). There is a little sway but the traction is well worth it. The ride is easy and smooth. Winter tires have softer/ playable rubber for the cold. I get the same gas mileage with the Blizzaks as I get on the dedicated summer 19 Michelin LTX.
The Q5 Audi I have, I have decided to replace the 20 inch ’CONTIS’ with Perelli Scorpion winters fromTireRack on the original 20 wheels. I am a little concerned of the traction with the wide foot print, more plowing, less weight per ground contact, etc... but I am looking at running these all year. They are in storage now and will be put on in December. Reviews were very good and several thought that this tire could be driven all year long. The tread pattern has slightly wider groves but not as wide as the Blizzaks. Time will tell and I’ll do a follow up in about three months.
P.s. I agree with smaller wheels for winter... laws of physics... more weight/pressure per sq inch and less plowing in the snow. You have to decide what looks good on your vehicle.
My theory is... it is better to spend $1200 - $1500 now on a dedicated winter set then to have an accident and spend $500 to $1000 deductible, with down time on the car....Also if your car is in an accident, CarFax will know and the trade in will knock another $1000 of the trade in value.
First I want to say that my families health and safety are the most Important concern.
BTW, running a smaller rim/wheel sized winter tire doesn't make much of a difference in deep snow if the width of the tire is the same, it's running a narrower tire with the same tire diameter that helps in those instances with the physics advantage.
If you want to ride snow *rated* tires all year, then you install All Terrain/Mudders.. My BFG KO2s are severe snow rated, and made of a compound that works all year long.. Good luck finding anything for 20's tho, they dont make All Terrains w/rubber band sidewalls.
Thanks.
Thanks.
Ok so I'm confused does my Canadian 2018 SQ5 have TPMS or not ?? I got a quote from 1010tires that included TPMS ...
