What mode is your instrument cluster in and why?
Old 11-13-2017, 05:56 PM
RJC 1's Avatar
Default What mode is your instrument cluster in and why?
I keep mine with the navi showing and the speedo/tach smaller, and use the pop up screen for music info.
Is there a way the vehicle can remember these settings? Each time we restart it goes back to standard display mode.
Old 11-14-2017, 04:46 AM
RickObe's Avatar
Nope. And as far as I know, nobody has discovered coding to fix it either. There is coding to delete some of the VC tabs if you want (audio, nav), but I don't think you can delete the trip computer tab.
Old 11-14-2017, 07:04 AM
JT4
JT4's Avatar
Usually I keep the speedo and tach on the smaller setting and toggle through what I need as I go.. I keep the map view on the "pop-up" screen 95% of the time..
Old 11-14-2017, 07:15 AM
BigKutta's Avatar
I switch based on need, but usually its small tach, and then other vehicle info in the center. I love to drive and enjoy every bend in the road and listening to the sound of the engine, so am not much of a tinkerer while driving.
Old 11-14-2017, 11:09 AM
RJC 1's Avatar
Thanks, just want the cluster to remember the display settings/configuration after re-starts
Old 11-14-2017, 12:46 PM
Cadx6's Avatar
Apparently 2017s don’t remember and default back to the Information screen. On 2018s (at least on my Q5) the VC returns to where it was when the car was turned off.
Old 11-14-2017, 06:57 PM
RJC 1's Avatar
Unreal, wonder why? Programming omission or still capable?
Old 11-15-2017, 05:50 AM
Brimstone's Avatar
I keep the speed/tach small 99% of the time and keep it on the trip computer screen a good 90% of the time and switch it around as desired, needed. (generally use nav/music if not on the trip computer)
Old 11-15-2017, 05:54 AM
N8DAGR8's Avatar
Any 2018 Q7s that can confirm this?
Old 11-15-2017, 06:03 AM
gsobol's Avatar
I can confirm that mine (MY2018) VC and center screen stay on the screens that were active at the time of shutdown. What that means is that if I keep music listing on VC and GPS on center when I turn off the vehicle (for the night), it comes back like that when I go to turn it on in the morning. However, not sure if VC maintains small gauges view (will check that), and not sure if center remembers the exact screen it was shutdown on (i.e. settings, destination input, etc.) will verify later.
Quick Reply: What mode is your instrument cluster in and why?
