Audi Q7 'no crank
Audi Q7 'no crank
So for a short story i took a turn and the steering wheel got heavy the car turn off message appears has ebs malfunction gearbox limited function low voltage batt and then car did not crank at all i just replace the battery leaving the computer connected with a jumper but still the same iissues car does not crank and has a new battery what could it be? Do i need to clear all the codes to it work?
Grey
reply
Well still not codes i havent got actually scanned but i just replace the battery with a new one keeping the car computer connected to a jumper but when i conmected the battery still al this error message appeared in display and no still cranks do i have to erase the codes for it to crank?
Grey
It has 78,000 miles and google conversion says 125528 km which is very low
Grey
i know but fuel pump should at least crank i got no crank after that turn steering wheel got heavy esp malfunction and gearbox limited then said low voltage batt and no crank at all
do i have to pair the new battery?
Does the car starter crank but the engine does not fire? That is how I understood your first post.
Grey
