D3 steering wheel upgrade
Old 12-11-2017, 05:32 PM
H-M3's Avatar
Default D3 steering wheel upgrade
Hi peeps just wanted a list of best steering wheel upgrades ppl have done on theirs. Mine is 4.2tdi with paddle shift, what’s the best plug n play upgrade?
cheers
Old 12-11-2017, 07:17 PM
Jack88's Avatar
You've pretty much got the best one.
Old 12-11-2017, 07:39 PM
awdinut's Avatar
Default aluminum
cheers
For my 2006 W12 I took the controls from a 2008-2010 A8 that have Aluminum trim and the Aluminum shift paddles from the same car. Brightened-up my world a little bit. Next I am swapping my window switches for Aluminum trimmed Q7 switches.
Old 12-12-2017, 01:08 AM
H-M3's Avatar
any pics? Is that plug n play the Q7 switches?
cheers
Old 12-12-2017, 02:56 AM
97urS6's Avatar
I have from the factory a hybrid solid wood with Leather around the main grip area's. It has paddle shifters and all of the MMI controls, etc. That package came with a matching solid wood shifter ****... very nice touch! The only thing I wish it had was the heater in the leather areas on the steering wheel... very nice feature on those -20c days!
Old 12-12-2017, 07:05 AM
awdinut's Avatar
Default almost P-N-P...
cheers
A couple of mm of plastic need to be trimmed away on the underside of the armrest. I will post pics if successful with that endeavor.
Old 12-12-2017, 02:45 PM
H-M3's Avatar
lot of guys in the UK are putting the Audi TTS steering, anyone here done that?
Old 12-18-2017, 01:20 PM
silkworm's Avatar
cheers
You can try replacing it with a D4 steering wheel, just as I did here, but please note that it's not quite plug and play, and you will have to do some modifications. The only thing that is fully compatible is the horn. Airbag also seem to be compatible (no errors on dash/VCDS), although I don't have a way to fully test it.
I still have to update that thread when I will finish with the multifunction keys modification (work in progress, I will finish in a couple of days... I hope ).
Originally Posted by 97urS6
I have from the factory a hybrid solid wood with Leather around the main grip area's. [...] The only thing I wish it had was the heater in the leather areas on the steering wheel...
Audi never manufactured heated wood+leather steering wheel. If you want a heated steering wheel, it must be full leather.
The only car manufactured by VAG group which has heated wood+leather steering wheel seems to be VW Phaeton.
If you are referring to the steering wheel with flat bottom, then I did that on my old A6 4F. It wasn't quite a sensation (except that it was brand new and with perforated leather), but I don't think it will look good on A8.
Old 12-18-2017, 08:21 PM
TSHong's Avatar
Definitely interested in that mod. I always thought that it would look very good.
Old 01-01-2018, 09:41 AM
H-M3's Avatar
I heard Audi S5 steering wheel are quite of a straight swap?
Marco Rosa
Q7 MK 1 Discussion
09-24-2016 09:27 PM
Marco Rosa
Q7 MK 1 Discussion
09-24-2016 10:42 AM
mwalshe2000
12
05-05-2015 12:10 AM
kinderutz
Audi 100 / A6 (C4 Platform)
11-16-2012 05:13 AM
Bundyman
05-08-2007 05:41 AM
Quick Reply: D3 steering wheel upgrade
