Loss of power
Loss of power
Hi guys, some times I drive s3 8p it feels like the turbo is not at its full potential, on the same day of feeling that, I switch it off and drive again, then it feels like a beast, my car is a 2007 model and only has 35k km on the clock, could your'll please help
It drives perfectly, no cutting out, just at some times it feels very under powered, switch it off and start again, then it's like it was reborn.
Do you have the option to check fault codes? What engine?
Sounds like a sticky MAF or a loose vacuum hose.
Just a guess without any codes.
For the MAF you can get some MAF spray cleaner, if you decide to unplug it and take it off to clean it, when you reinstall turn the ignition on but not start. The maf should go through a re-commissioning set up, full open, full close a couple of times. After it stops then it should be good to start the engine.
A loose vacuum would produce a similar feel to a faulty DV, which you were on that path since you changed the DV. Just a thought.
ssnsteamboat
03-13-2014 06:27 AM
Guilty
09-02-2005 05:15 AM
BSCA4
01-26-2004 11:25 AM
