Dedicated Phone for AA?
We have a couple of unused Galaxy phones around the house - an S5 and S6 edge. Neither have active cell service, but apps that just use wifi run just fine. I was thinking about dedicating one of them to my (hopefully) soon to be arriving SQ5 for Android Auto. Has anyone done this and, if so, how did it work?
1. You'll need to take the phone out of the car and charge it every so often. Having it charge only when you have your car on might not be enough.
2. The only problem you'll have is with telephony. You won't be able to place or receive any phone calls in your car, or text messages. You also can't connect a secondary phone via Bluetooth when AA is connected to your car, this is disabled.
Note you get 6 months free of hotspot date on a new car from Audi so your data would be free for this time.
Yeah this will generally work well, with two caveats:
As for a secondary phone, our Audis have this option when you're using Bluetooth for both, but you will see that this is disabled when Android Auto is running. Unfortunately, this is part of the requirements that only the Android Auto phone be allowed to do telephony when its connected. This might change in the future, but if it does, it would require an update to the car's software, not just the apps running on the phone.
I've confirmed this on my car, but let me know if it's different on the Q5.
Hey there -- charging can be an issue because you're only going to be charging when the car is on. Depending on how often and for how long you drive -- and also the efficiency of the phone's standby and the apps you have on the phone -- your dedicated phone will probably not have enough standby battery after a little while. Note that older versions of Android before Android M were much worse in terms of standby system health than the newest stuff.
yes, standby time is a concern .I suppose if someone is doing this they could charge the phone once every few days. As for the telephony operations while using AA with 2 phones you're probably correct; I have not tested the method yet . AA streams all audio over Bluetooth based on using it for 1.5 years now .
If so, the implementation is strange. When I toggle bt off no music will play from my phone in AA .only when BT is only will it work .
