Crankshaft position sensor location 2013 Audi A6
If you have 2.0L, then Audi manual calls it an "Engine Speed Sender", and it is #9 back of engine driver's side, it reads a wheel on end of crankshaft.
Middle back in pic
Middle back in pic
According to my manual is #10 for my 2012 A6 3.0T Prestige.
Here's the instructions it provides-
Remove noise insulation (rear) ⇒ General body repairs, exterior; Rep. gr. 66 ; Noise insulation; Removing and installing noise insulation .
– Remove bolt -arrow- for coolant pipe on gearbox (right-side).
– Remove bolts -arrows- and push ATF cooler slightly to one side.
– Unplug electrical connector -2-.
– Unscrew bolt -1- and pull out engine speed sender - G28- .
Installing
Installation is carried out in the reverse order; note the following:
– Install ATF cooler ⇒ Rep. gr. 34 ; ATF circuit; Removing and installing ATF cooler .
– Install coolant pipe (right-side) on gearbox ⇒ page 235 .
Last edited by payedmercenary; 11-19-2018 at 08:44 AM. Reason: Adding vehicle information
haikaa (11-15-2019)
The engine speed sensor G28 looks like located on the left top side of the engine on the diagram.
However, it is deceiving. It actually is hidden under the ATF cooler and need to be accessed from bottom of the engine.
Adam Mills
03-29-2019 11:28 AM
tanya_charbury
09-14-2017 02:32 PM
gateway
12-02-2012 11:09 AM
fehong
04-21-2005 01:27 PM
