Who has had the diesel emissions fix done on a 2014 A6 TDI and results?
Looking for feedback if anyone has had the diesel emissions fix done a 2014 A6 TDI.
Thanks. Just about time for me to bring my car in for 4 year service. I'm going to ask the dealer if they've done any of the repairs yet and if so, how many. I don't want to be the guinea pig here.
Had mine done 1/10/18
Hope this helps.
-Took a while to get the appointment. The service advisors played ignorant until mid-January then set me up with an appointment and a loaner.
-Be sure to have your claim number with you.
-When I picked up the car after the service the adblue tank had been filled but not the fuel tank. I had to show the service advisor my booklet and he apologized and had the tank filled.
-To make a long story short, neither my wife nor I can find a single difference in the car before and after. I have read that it might sound a bit different at idle, but we've noticed no difference. Someone on another forum mentioned an odor from the exhaust. Even running the car in the garage we've noticed no such odor. No discernible change in acceleration, and no noticeable difference in the way the car shifts. I don't have enough miles on the vehicle to say if fuel economy has been affected but the DIC indicated mileage seems pretty typical. My wife and I might well be non-observant, but if we hadn't known that the emissions fix had been done we would have never known the difference. Just my $0.02.
Had mine done the end of January and have put 700 miles on it since then - no discernible difference in performance, MPG, NVH, etc.
I mentioned the full tank of fuel to the service advisor when I brought it in, which he was unaware of. I showed him the booklet and he added it to the service order.
Summary: No discernible difference once engine has warmed up (and differnces during warm up mode are barely noticeable).
Thank you very much for the feedback. Your experience sounds like what I've been anticipating based on everything I've read.
I had it done this past Saturday. Feedback is as following:
And I got paid on Tuesday
- No discernible difference in engine noise - still sounds the same.
- Cold start shows no different in RPM - around 950 RPM at startup and about 750-775 after initial warming cycle completes.
- Gas mileage appears to be, more or less, the same - I will need to do a couple of tanks before I can tell for sure.
- It does shift later than it used to, especially when cold. And, it also holds gears for longer - i.e. when I cruise at 55 and secondary warm-up cycle not fully complete, it'd hold 6th gear as opposed to 7th gear. I also noticed that when going uphill (and this after it has complete warmed up), it will downshift to a lower gear at the same load as opposed to pre-fix where it'd keep existing gear - i.e. I could be doing 65 uphill in 7th before the fix but now it will downshift to 6th and hold higher RPM.
- It feels throttle response has been neutered a little bit when in regular D mode. You need to push the go-pedal a bit further before it downshifts and scoots.
- Power delivery does appear to be unchanged, though.
