S4 b8 2011
S4 b8 2011
Hey so I've been looking at purchasing an s4 (I currently have an A4) but I was curious just how common the mechatronic problems really are for the b8 model. More specifically the 2011 model.. I really don't want to spend most my money on a model that would have a high chance of something really costly braking. I see alot of threads about the mechatronics but obviously you wouldn't see any threads of how flawless their s4s have been so I want to put the general question out of what you guys think the chances are of something big breaking. Low/med/high
also at what more recent model/year does the mechatronic fault seem to have been fixed? Thanks in advance
Have you considered one with a manual trans. Much harder to find .But you could need to replace the clutch assembly at some point in time. BTW, these cars have been really reliable ,even with high mileage. Much better than anyone ever expected. As with any German car with higher mileage, components will fail and can be expensive to repair. I purchased an extended warranty when I bought my 3rd B8 S4(2011) with 49K miles . After 3 yrs and 25k miles I had no claims. I feel like I pissed $2700 away. Now with 80k miles and no warranty, car running like a top. I have had to replace the battery ,tires, brakes and rotors which I consider normal wear and tear items. I also had to replace the thermostat. ALL t stats will fail .Most between 70k and 80k miles. While the supercharger was off, I also had them replace the water pump,PCV valve ,coolant tube, change the oil in the SC and replace the serpentine belts. Cost me $1500, But I feel like I will not have to need to take off the SC again or address these issues in the future
so there's a manual transmission in my area that I'm also interested in. It's done 21k miles also 2011 model. If I was to go for that, it would eliminate the mechatronic problem but what other problems could I expect. I know the thermostat problem is common in these models. Heard the thermostat is under the supercharger which is the only costly thing about that (But not too bad). Thanks for your input about manual, makes my decision easier.
Hijacking the answer from DrGP, but if i had found a b8 manual with only 21k I would have jumped on it immediately. that's incredibly low milage. the only other "problem" that is really common is the clutch pedal start cancel, where the slave cylinder rod is just a tiny bit too short and you have to really put the clutch pedal to the floor to get it to start. There's a well documented fix on this forum about a fella who makes replacements in his garage and sells them for a reasonable price, and the fix is easy enough to do in an afternoon. The s4 i just bought with 85k miles has the issue but its not that noticeable, the point where it senses it is just a bit lower than normal, and still higher than my 5-speed truck, but Its something I know ill probably have to address in the future.
dealer or private? i payed 24k at a dealer for a 2013 with 85k. If it has all the options you want and the dealer is willing to throw in some AudiCare for the next few services, Id say its a pretty good deal. 25k was the limit of my budget but i would have like to get a lower milage model
Mine was a manual, I didnt think it was that much of a value adder. Definitely ask for a drive, see what you feel better driving. Do either of the ones you're looking at have the Sports Diff? If you plan to do any spirited driving its generally agreed that its a must-have.
unfortunately no, although i did see one thread where someone was looking for replacements and salvaged diffs were less than a grand on ebay, as opposed to something ridiculous like 15k new
