Which Wiper Blades for 2009 A4 Quattro Cabriolet?
I am having trouble finding the correct replacement wiper blades for a 2009 A4 Quattro Cabriolet.
The blades are removed by sliding a cover piece off the wiper arm. The blades have a notch in the pivot point. I have attached some pictures.
Can someone recommend a type/brand?
Richard
Richard
Richard
Richard
Suggest you measure the lengths of the DS and PS blades...if they are different you may have to purchase them separately or if by pair that one is longer than the other. If they are the same length, than order in a pair. Bosch is the blade of choice if aftermarker, otherwise go with Audi ones but be prepared for sticker shock. On my 2006 A4 Cabriolet they were the same length at 22" so I got these at Amazon:
Suggest you measure the lengths of the DS and PS blades...if they are different you may have to purchase them separately or if by pair that one is longer than the other. If they are the same length, than order in a pair. Bosch is the blade of choice if aftermarker, otherwise go with Audi ones but be prepared for sticker shock. On my 2006 A4 Cabriolet they were the same lenth at 22" so I got these at Amazon:
http://www.amazon.com/Bosch-Aerotwin...ype=automotive
Please look at the pictures I sent. Do my wiper arms look like the setup on your car, where I assume you used these blades?
Richard
Yes, my blades used the single cover and the blades arched with mounting bracket in the middle...s/b fine. Post up when you get them fitted successfully...I'll take a picture and post up later when my son gets home from work with the car if you want.
Richard
TJquattro
06-03-2018 02:01 PM
