Replacing Air and Cabin Filter
The cabin filter is easy. No tools needed.
Go under the passenger dash, look up, and remove the two thumb screws securing the cover. The cover is flexible so bend it as needed. You will then see a flat plastic cover for the filter curved like a banana towards the door side of the dash. Around the cover are small clips that are released by hand, work from the long straight side towards the curved end. After the cover is released you can easily pull the cabin filter out. Install new filter in the proper flow orientation and reverse the process.
The engine air filter is more involved, and I think the change interval there is at 60k miles. Once I hit that mark I'll post a guide.
keaton824 (11-03-2021)
Remove the screws
Slightly pull it out
Air filter. Remove by twisting it out
Thanks I will try opening the cabin filter as you said. I was able to get the air filter open as such by just removing screws. Thw filter is circular and is twist off. Attaching photos of it.
I think it really depends on your environment too. From my understanding, people who live in AZ have to change their filters way more often because of all the dust storms. If you live in other places like Montana, it could last that long if not longer. I would say it doesnt hurt to check it every 10k(after 30k) and make the decision to replace at that point.
Just cleaned the engine air filter chamber and the air filter. The dirtiest filter chamber I ever saw. Lots of leaf debris and other dirt. Small leaf debris stuck in filter media gaps. Had to pound them off or air blow them off. I am right at 30k miles, thinking to change it.
I just changed my air filter and cabin filter at 13500 miles (I'm old school). The air filter was still pretty much clean and I was surprised. Just use a T20 screwdriver and remove the 6 screws.
Everything I read about the horror stories about the cabin filter I never ran into. Yes, it is in an awkward position and if you are a noseguard for the Steelers then you will have your problems. Find someone smaller to do it for you. The filter door was easy to snap on and off. The filter curves easy enough and fits nicely into the housing.
Well, I managed to change the aforementioned filter!! I'm certainly not the most practical minded person, so feel a sense of achievement with doing this!! Doubt I'll have attempted it without this thread though, so a big thumbs up to all the contributions above. No clips broken, no screws, back ok, although my neck took a bit more of a beating in getting under there.
