Car pulling to right?
Two weeks in with my SQ5...feels like my car is pulling slightly to the right (need to make leftward adjustment with my steering wheel). This is more noticeable at highway speeds which was why I didn’t pick it up on delivery test drive. Has anyone else had to deal with this?
Not likely, but just a thought: if you have Active Lane Assist, make sure it isn't trying to correct your lane position and pull you to the right (if you tend to drive to left of center in the lane).
Yes I noticed this on my Q5 Prestige. I noticed it when I try to make the Audi rings on the steering wheel perfectly straight the car would pull to the right The steering wheel is off like 1 deg from being flat. They realigned the car, its much better but the wheel is still slightly off. I have noticed it on both loaners as well that I have had the wheels are slightly off.
This was mentioned in a few topics. I cannot find the thread where someone bring it to a shop where he had a certain brand that didnhe alignment to fix it. But I did find this thread see below: hope this helps. Will be getting my sq5 in Jul fingers crossed that this does not happen.
https://www.audiworld.com/forums/q5-sq5-mkii-discussion-218/issue-new-sq5-3days-2935851/
Both of my SQ5's need an alginment within the first 1000miles. Have your dealer throw it on the hunter machine and check the factory alignment, it's probably off.
If you can go to one of the Sewell Audi dealers there (Sugarland and North Houston). I bought my car at the NH one and honeslty they set the bar for all car dealers. The service manager there is very professional and knows his stuff. They should not change for an alignment given how new the car is.
