2007 windshield wiper fluid reservoir removal
I’m stuck, how do I get this thing out of the wheel well?
There is a leak that I can’t track down without removing the reservoir. Any help would be greatly appreciated.
manual says:– Remove front wheel housing liner (left-side)– Unplug electrical connectors -2-, -3- and -4-.– If fitted, unplug electrical connector at tyre pressure monitor sender unit in front left wheel housing -G431-.– Press release tab and pull off hose connector -1-.– Detach washer fluid pipe -5- at washer fluid pump.– Unscrew bolt and nuts -arrows-.– Detach washer fluid reservoir from studs.– Take out washer fluid reservoir downwards
cheers!/H
cheers!/H
audiareluxury
08-13-2005 02:37 PM
coasTTal
TT (Mk1) Discussion
01-23-2002 03:26 PM
