Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Resonator delete sound question
Old 06-18-2018, 10:24 AM
M0J0's Avatar
Default Resonator delete sound question
My S3 came with the delete. I am not sure if I really like how loud the sound is. It is louder than my old M3 with cat delete. It also does not sound that great.
Old 06-18-2018, 12:42 PM
Timmay's Avatar
Interesting. You are the first one that I can remember stating you don't like the sound of the res delete. Hard to believe it's actually louder than your M3 also with cat delete. Are you referring to the sound inside the cabin or outside of the car?
Btw, what is your actual question? LOL.
Old 06-18-2018, 03:05 PM
uniqueMR's Avatar
Louder than M3? Hmmm, I have M4 and I bet you my M4 is way louder than my S3 with resonator delete
Old 06-18-2018, 04:39 PM
M0J0's Avatar
Inside the car.
Old 06-18-2018, 07:26 PM
marttimat's Avatar
Inside the car.
Have you turned down / off the A7 Module (interior engine sound controller)? That would affect the interior exhaust note quite a bit. Also, I assume if no then you have the exhaust flaps operating normally? Having them unplugged will make the exhaust note louder outside of the car.
Old 06-19-2018, 04:20 AM
whitby's Avatar
Default I took the resonator out - no regrets
My S3 came with the resonator - I took it out. The sound is better without, IMO. It is louder though not intrusive inside the car.
Old 06-19-2018, 05:22 AM
Timmay's Avatar
Inside the car.
Do you drive your car in automatic mode? If yes and in Dynamic setting it can definitely get loud as it holds the RPMs pretty high. I drive manually so don't encounter that unless I intentionally rev it high.
Old 06-19-2018, 08:50 AM
Flying Scotsman's Avatar
There are many opinions, both pro and con on the res deletion on other sites. The most common negative was excessive drone between 2,800-3,500 RPM which some found very annoying on freeways/motorways/autobahns.
Old 06-19-2018, 01:18 PM
M0J0's Avatar
This is a big part of why I do not like it. I noticed some drone. I would just rather have a more quiet car. It is a 4 banger. It is not supposed to sound angry.
Old 06-19-2018, 01:35 PM
Timmay's Avatar
Tell that to owners of Evos or Subie STIs. I don't think it sounds angry unless you're punching it. Btw, didn't you test drive it before purchase?
Quick Reply: Resonator delete sound question
