Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Noise at 90 and 180kmh
Old 07-21-2018, 10:45 AM
Matteo Trevisan's Avatar
Default Noise at 90 and 180kmh
I just bought a 3 years old audi A3, I love it except that it makes a humming noise from the front of the car when running at 90km/h and 180km/h. The car by Italian law should have a limited warranty from the dealer for one year, since he is a professional used car dealer, but it seems like he has not really clue on how to fix the problem.
The dealer suggested to:
- Change Tyres (done at my expense, with no result)
- Change Front Bearings (done at his expense, with no result)
I made a video, showing also an home made spectral analysis of the noise:
The car makes the noise also when in neutral and with clutch pressed, so the generator of the noise should be between the gearbox and the tyres.
The noise has a frequency of 50Hz and 150Hz. The wheels at 90kmh rotates around 12,5Hz and at 180kmh rotates around 25Hz.
I read a very long discussion on this forum about a problem that seems really similar to mine: https://www.audiworld.com/forums/a8-...2872385/page5/
It seems that someone resolved changing or simply rotating by 180 degrees a driving shaft, someone changed the whole car.
Do you have a clue about what could generate this kind of noise?
Thank you in advance.
Old 07-21-2018, 12:32 PM
iampraneel's Avatar
I made a video, showing also an home made spectral analysis of the noise: https://youtu.be/SGXMy__bnac
Mine made a similar noise and it was the wheel bearings. Did they check the rears.
Old 07-22-2018, 07:02 AM
Faulty bearing noise isn't usually with higher pitch and audible from a certain speed up? They actually told me that they changed only one of them and solved the problem, but nothing changed actually...
harriet
S4 (B8 Platform) Discussion
12
08-06-2010 08:56 AM
MK1.8TQMSBlack
07-07-2005 08:26 PM
Black4.2S4Vin
09-01-2003 06:46 PM
notjcs
07-09-2002 07:23 AM
s4hon
04-09-2002 07:12 PM
Quick Reply: Noise at 90 and 180kmh
