Help repairing mmi
2005 Audi A6 MOST bus/mmi diagnostics and repair
Rear trunk radio equipment picture
Hi guys,
I dont post often but follow the forums pretty close. I recently acquired a low mile 2005 a6 quattro but it had many issues. Most of them wiring related.
One issue that has driven me nuts was the cracked lcd for the nav and that the previous owner rewired for an aftermarket radio removing the 6 disc changer and putting a crap pioneer headunit in there.
I have access to a wrecked s6 of same year and have got a new screen for it but as they rewired it, it does not work.
is anyone in possession of a full schematic for the mmi system from this car? It would be a ton of help.
the car is a 2005 audi a6 quattro 4f (3.2 fsi engine)
thank you for any help you can offer.
right now my vcds reports no communication with control head and radio. Here is a picture of the trunk want to know if anything appears missing. Also need to know location of other components. As an audi enthusiast and electrical engineer I'm sure I will figure it out but the schematic would really help. I cant manage to access the bently software even running a vm so hopefully someone here can.
thanks again.
So I have reconnected all the wires and optical cables. Two things it appears this car didnt have nav as I dont see a nav controller or wiring harness, next I am not sure where the display controller is located.
vcds gives all errors when I try to run an optical data bus diagnostic.
I replaced the display itself but I get no picture. The amplifier appears to work as does the CD changer. The control head has no lights I have removed it but havent had a chance to open it up.
I have read that there is a bluetooth receiver under the driver seat. I am afraid some liquid got down there as the driver seat power is not working nor is the memory. This is also reporting error on vcds. So I'm wondering is any of the radio parts under the seat.
the symptoms are
no audio
blank screen
no lights on control head
it would be helpful to know if there is a seperate display controller as in an a8 or anything else I might be overlooking
I can post the vcds scan later today for what good it might do.
the symptoms are
no audio
blank screen
the symptoms are
no audio
blank screen
the symptoms are
no audio
blank screen
Yes I will need to get one of those lollipops I cant find mine. I wonder if I can 3d print something to use a regular optical cable.
my other question is that i do not see that module...
vcds autoscan
I've been trying to post the vcds scan, however my account was made through single sign on with google account. this only works on mobile browsers apparently. i had to emulate a mobile browser to make this post because otherwise it says i'm not logged in.
Anyways here is the scan from the car. I know its alot :/
Wednesday,15,August,2018,17:24:00:11610
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WAUDG74F25N105831 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 72 77
VIN: WAUDG74F25N105831 Mileage: 167430km-104036miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A0D018EC0FDFCF70F0-807E
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:08:03
Freeze Frame:
RPM: 1472 /min
Mass Air / Rev.: 196.2 mg/str
Temperature: 31.5°C
Idle
Load: 23.9 %
Speed: 0.0 km/h
29698 - Please Check Fault Codes in Comfort System Control Module (J393)
U1002 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:08:05
Freeze Frame:
RPM: 1056 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 46.5°C
Idle
Load: 28.6 %
Speed: 0.0 km/h
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0080185
Coding: 0001002
VCID: 290FFE82C5FBF7EF06A-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02327 785 00200
VCID: 2D070A92F113EBCFEA2-8078
7 Faults Found:
01418 - Switch Valve 1 for Electronic Stability Program (N225)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 68
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:34:49
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x0016
Hex Value: 0xC0AC
Hex Value: 0x00FF
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 68
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:34:49
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x001C
Hex Value: 0xB1AC
Hex Value: 0x00FF
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 67
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:38:43
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0021
Hex Value: 0x41AB
Hex Value: 0x00FF
00274 - ABS Inlet Valve; Rear Left (N134)
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 31
Reset counter: 30
Mileage: 166469 km
Time Indication: 0
Date: 2005.02.02
Time: 00:57:06
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x000F
Hex Value: 0xC0AA
Hex Value: 0x00FF
01200 - ABS Valves Supply Voltage
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 45
Reset counter: 30
Mileage: 166469 km
Time Indication: 0
Date: 2005.02.02
Time: 00:57:08
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0002
Hex Value: 0xC0AB
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 10
Reset counter: 30
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 15:23:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0035
Hex Value: 0x0183
Hex Value: 0x00FF
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 15:42:01
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6782
Hex Value: 0x0013
Hex Value: 0x808B
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601260190
Coding: 0000011
Shop #: WSC 05120 444 999999
VCID: 2517F2B2A9E3D38F222-8070
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0054
1 Fault Found:
01176 - Key
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 43
Reset counter: 40
Mileage: 166469 km
Time Indication: 0
Date: 2005.02.02
Time: 00:56:56
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000026 Serial number: 00000000119586
Coding: 0524326
VCID: 5BE3944ADF27557F446-800E
3 Faults Found:
01857 - Air Outlet Sensor; Middle Left (G347)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 15
Reset counter: 70
Mileage: 166471 km
Time Indication: 0
Date: 2005.02.02
Time: 03:43:02
01858 - Air Outlet Sensor; Right Center (G348)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 23
Reset counter: 30
Mileage: 166471 km
Time Indication: 0
Date: 2005.02.02
Time: 03:45:22
00739 - Coolant Circulation Pump (V50)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 36
Reset counter: 69
Mileage: 166534 km
Time Indication: 0
Date: 2005.02.03
Time: 07:22:18
Freeze Frame:
Temperature: 74.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
Shop #: WSC 02335 785 00200
VCID: 6695B5BE14651897EB8-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
01498 - Bulb for Parking Lamps; Right (M3)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:00
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 30
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:35:00
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:00
01834 - Bulb for Side-Blinkers; Left (M18)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 45
Reset counter: 30
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:35:00
01835 - Bulb for Side-Blinkers; Right (M19)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 30
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:35:00
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D088X3$
Coding: 0013622
Shop #: WSC 05140 444 85886
VCID: 2615F5BED4E5D8972B8-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME0768426F9
Subsystem 3 - Serial number: 6342CSME08762337+
Subsystem 4 - Serial number: 6351HSME065D06153
Subsystem 5 - Serial number: 6361HSME064A1F67H
Subsystem 6 - Serial number: 6371VSME062B502DM
Subsystem 7 - Serial number: 6381VSME0622120DA
1 Fault Found:
01316 - ABS Control Module
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050480043
Coding: 0002041
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0630
Revision: 00500000 Serial number: 4R8164T25
Coding: 2113263
Shop #: WSC 05141 444 50585
VCID: 1E65DD5E8CB50057638-804A
2 Faults Found:
02759 - Operating Switch for Instrument Cluster
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 30
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800805224024D
Coding: 6CFE73CC1B1904
Shop #: WSC 05140 444 54400
VCID: 270BF8BAD3EFC19F10E-8072
6 Faults Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:31:31
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:38:34
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 30
Time Indication: 15
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 13:56:07
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:12:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Address 36: Seat Mem. Drvr
Cannot be reached
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0035563
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 243
Reset counter: 30
Mileage: 165889 km
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 70
Mileage: 165992 km
Time Indication: 0
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01003012580000
Coding: 0423997
VCID: 2C010796CA09E2C7FDC-8078
Subsystem 1 - Component: Sounder No Answer
7 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 49
Mileage: 152017 km
Time Indication: 0
Date: 2005.02.22
Time: 06:07:32
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 30
Mileage: 158334 km
Time Indication: 0
Date: 2005.10.05
Time: 13:51:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 13:56:08
Freeze Frame:
Fault Priority: 3
Reset counter: 30
Mileage: 160481 km
Time Indication: 0
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:00:08
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 15:37:03
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 10
Reset counter: 49
Mileage: 160494 km
Time Indication: 0
Date: 2000.00.00
Time: 16:59:24
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000070653
Coding: 0001114
VCID: 5EE59D5ECC354057238-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:00
Freeze Frame:
Voltage: 10.300 V
Temperature: 32.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: G I
Coding: 0035563
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 60
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:29:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
VCID: 5DE79A52C1335B4F3A2-8008
4 Faults Found:
02442 - Function Lamp in Control Head
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 30
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 15:23:55
Freeze Frame:
Voltage: 10.87 V
Count: 65
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 45
Reset counter: 30
Time Indication: 0
Freeze Frame:
Voltage: 11.28 V
Count: 40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Freeze Frame:
Voltage: 9.73 V
Count: 242
Freeze Frame:
Fault Priority: 3
Fault Frequency: 225
Reset counter: 70
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:40:13
Freeze Frame:
Voltage: 13.25 V
Count: 236
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
5 Faults Found:
02629 - Sensor for Swivel Module Position; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:27:18
02631 - Voltage Supply for Swivel Module Position Sensor; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 61
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:27:18
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Fault Frequency: 49
Reset counter: 30
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:39:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 49
Reset counter: 30
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:39:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000024611
VCID: 2313ECAAA7D72DBF4C6-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2502160660
Coding: 344630393135313035432056413032353032313630363630
Shop #: WSC 00000 384 00290
3 Faults Found:
02254 - Interface to Generator
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:09:15
02479 - Partial Consumer Shut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:09:15
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 21:19:53
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0035370
VCID: 698FBE82057B37EFC6A-803C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0035370
Shop #: WSC 02327 273 00064
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:30, VBatt start/end: 13.6V/13.4V)-----------
www.Ross-Tech.com
55 56 61 62 72 77
2 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:08:03
Freeze Frame:
RPM: 1472 /min
Temperature: 31.5°C
Idle
Load: 23.9 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:08:05
Freeze Frame:
RPM: 1056 /min
Temperature: 46.5°C
Idle
Load: 28.6 %
Speed: 0.0 km/h
Coding: 0001002
Coding: 0020895
7 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 68
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:34:49
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x0016
Hex Value: 0xC0AC
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 68
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:34:49
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x001C
Hex Value: 0xB1AC
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 67
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:38:43
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0021
Hex Value: 0x41AB
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 31
Reset counter: 30
Mileage: 166469 km
Time Indication: 0
Date: 2005.02.02
Time: 00:57:06
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x000F
Hex Value: 0xC0AA
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 45
Reset counter: 30
Mileage: 166469 km
Time Indication: 0
Date: 2005.02.02
Time: 00:57:08
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0002
Hex Value: 0xC0AB
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 30
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 15:23:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0035
Hex Value: 0x0183
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 15:42:01
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6782
Hex Value: 0x0013
Hex Value: 0x808B
Hex Value: 0x00FF
Coding: 0000011
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Reset counter: 40
Mileage: 166469 km
Time Indication: 0
Date: 2005.02.02
Time: 00:56:56
Cannot be reached
Coding: 0524326
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 70
Mileage: 166471 km
Time Indication: 0
Date: 2005.02.02
Time: 03:43:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 30
Mileage: 166471 km
Time Indication: 0
Date: 2005.02.02
Time: 03:45:22
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 69
Mileage: 166534 km
Time Indication: 0
Date: 2005.02.03
Time: 07:22:18
Freeze Frame:
Temperature: 74.0°C
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 30
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:35:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 30
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:35:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 30
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:35:00
Cannot be reached
Cannot be reached
Coding: 0013622
1 Fault Found:
Coding: 0002041
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Coding: 2113263
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 30
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:31:31
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:38:34
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 30
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 13:56:07
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:12:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Cannot be reached
Revision: 00-00000
Coding: 0035563
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 30
Mileage: 165889 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 70
Mileage: 165992 km
Time Indication: 0
Coding: 0423997
7 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 49
Mileage: 152017 km
Time Indication: 0
Date: 2005.02.22
Time: 06:07:32
Freeze Frame:
Fault Priority: 3
Reset counter: 30
Mileage: 158334 km
Time Indication: 0
Date: 2005.10.05
Time: 13:51:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 13:56:08
Freeze Frame:
Fault Priority: 3
Reset counter: 30
Mileage: 160481 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 14:00:08
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 15:37:03
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 49
Mileage: 160494 km
Time Indication: 0
Date: 2000.00.00
Time: 16:59:24
Cannot be reached
Coding: 0001114
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:00
Freeze Frame:
Voltage: 10.300 V
Temperature: 32.0°C
Coding: 0035563
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 60
Reset counter: 30
Mileage: 166466 km
Time Indication: 0
Date: 2005.02.02
Time: 00:29:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Revision: C63C0030
Coding: 0005022
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 30
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 15:23:55
Freeze Frame:
Voltage: 10.87 V
Count: 65
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 30
Time Indication: 0
Freeze Frame:
Voltage: 11.28 V
Count: 40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Freeze Frame:
Voltage: 9.73 V
Count: 242
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 166464 km
Time Indication: 0
Date: 2005.02.02
Time: 00:40:13
Freeze Frame:
Voltage: 13.25 V
Count: 236
Coding: 0000016
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:27:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 61
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:27:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 49
Reset counter: 30
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:39:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 49
Reset counter: 30
Mileage: 166472 km
Time Indication: 0
Date: 2005.02.02
Time: 00:39:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 70
Mileage: 167432 km
Time Indication: 0
Date: 2005.02.01
Time: 14:19:37
Address 56: Radio
Cannot be reached
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:09:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 16:09:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 21:19:53
Coding: 0035370
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Coding: 0035370
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 70
Mileage: 167433 km
Time Indication: 0
Date: 2005.02.01
Time: 12:04:00
Cannot be reached
optical databus diag
This is something I've ne evr een seen! when running the optical databus diagnostic heres what we see:
screenshot from optical data diagnostic all errors
I think I found the problem.
after removing all the trim, seats, then carpet this is what I discovered inside of a sealed black plastic box. It would appear that It isnt sealed so well.
I'm going to take it apart and see if i can repair it (unlikely) but as I dont have an odis subscription I'm not sure how to recode a replacement... I have a donor s6 that worked until a crash.
any advice here? Which module is it?
Floor befor removal
Control module covered in a white powder most likely from electrolysis from water
Control module covered in a white powder mosr likely from electrolysis from water
Floor after removal
Floor befor removal
Floor after removal
