Sport mode vs. "Drive Select Engine/Trans = "Dynamic"
When I put the transmission into "S", how does that differ from using the Engine/Trans "Dynamic" (and/or Steering = "Dynamic") selections?
Or is "S" just short hand for choosing Drive Select = "Dynamic," which ostensibly sets both Engine/Trans and Steering to "Dynamic."
Thanks!
Thanks!
In the Q5, without any adaptive suspension, there is no difference between shifter in S and drive select in dynamic... the only thing that could possibly be different is traction control but I dont know of that feature if its there.
Drive Select Dynamic sets the transmission to S, engine to Dynamic, Steering to Dynamic, Suspension to Dynamic and anything else the car is equipped with to Dynamic. S by itself only sets the engine to Dynamic and the transmission itself obviously, but everything else such as Steering stays in the current Drive Select mode. So in other words S = Dynamic for engine/transmission only. This also means that if you put Drive Select in Dynamic, but then put the transmission in D, the engine goes back to Comfort/Auto, so basically the transmission mode takes precedence over the Drive Select mode as far as engine and transmission are concerned. It should also be said that there are two manual modes, M and M Sport. The latter is engaged if you first put the transmission in S and then M.
BTW, there are several other threads on this forum already that answer this exact question. They should have come up with a search.
Thanks - did did search this forum and found a few discussions that are SQ5 related, but it is clear there are differences with the Q5. I did not see anything that was Q5 (not "S") in nature. Sorry if I missed them, feel free and direct me to another thread if this one is not appropriate.
What it seems to me, based on what I have read and "feel":
- Drive Select: Dynamic - in some cars this actually changes the setting to "S" in the display. It does not in mine.
- Selecting "S": Dynamic for engine/trans ("E/T") ONLY go to Dynamic
- Selecting "S" then change Drive Select Comfort: "E/T" stays in Dynamic
- Drive Select Dynamic, then shifting to "D". E/T stays in Dynamic
- Drive Select Comfort, then shifting to "S". E/T goes to Dynamic
- Your car will be in E/T dynamic if either or both: (i) you are in "S" or (ii) Drive Select E/T Dynamic
- Your car will be in E/T comfort only if you aren in "D" and Drive Select E/T Comfort.
In Dynamic mode, the steering also becomes heavier along with the transmission in S automatically. In sport mode, only transmission map changes. Steering feel doesn’t. Steering feel depends on drive select.
Slices_of_time (07-05-2020)
from Audi website that explains dynamic drive select
2018 Audi Q5 Engineering | Audi Q5 | Audi USA
