EMD RS Grille/Front Parking Sensor Issue
Old 10-14-2018, 09:35 AM
arrtewwx's Avatar
Default EMD RS Grille/Front Parking Sensor Issue
I had a RS style grille (mine is from EMD) installed in my A5 SB this past week and all was well. However, today I got in the car to head out and the front driver side sensor kept going off intermittently. I am guessing this means I’m going to have to go to the dealership to get the sensors calibrated (and cost $$- since it won’t be warrantied). Has anyone, with a modified grille. encountered this type of issue and/or had it resolved?
Old 10-14-2018, 10:41 AM
BreedsAs's Avatar
Happened to me too. I was able to resolve the issue and you will not need any calibration.
Things to check:
1. Ensure the sensor harness wires are not too tightly pulled.
2. Make sure the sensor is properly aligned in the provision of the RS grille.
Old 10-14-2018, 12:00 PM
Trade_it_all_4_more's Avatar
In addition to BreedsAs suggestions, make sure the rubber grommet is properly seated on the sensor. While I did not run into any issues, I was able to see that the sensor was not properly seated prior to putting the bumper back on (fixed it), and it was due to the rubber grommet.
Old 10-14-2018, 12:15 PM
arrtewwx's Avatar
Excellent suggestions, thank you. It could have been a grommet or alignment issue, but a quick spit shine on the sensor seems to have fixed the problem! The sensor looked clean, but as @BreedsAs knows, we got a lot of rain in DFW Fri/Sat. Maybe while I was giving it a quick clean, it could have set the grommet or slightly aligned it again. Time will tell, but hoping it’s fixed!
Old 10-18-2018, 06:52 AM
arrtewwx's Avatar
Unfortunately, the issue reappeared intermittently so I am working with EMD to see if I can get a new sensor sent to me.
Old 10-20-2018, 08:46 PM
3cat's Avatar
My front sensors are triggered sometimes for no apparent reason. Although I can't recall if it happened before the grille swap or not.
Old 10-21-2018, 04:53 AM
Club AutoUnion
Nikon1's Avatar
Received 2,145 Likes on 1,378 Posts
My EMD grille went on Wednesday and so far no problems. I did scour the various threads devoted to this grille install and made sure to follow all the advice posted (Thanks to all that came before!).
Cv640pilot (06-21-2019)
Old 10-21-2018, 08:02 AM
bayarea_s5's Avatar
Have the same problem, but EMD didn’t even bother replacing the grill or the sensors even after numerous emails of “follow ups”. I even bought new sensors coz mine intermittently comes back on when that side gets wet and water sits there. I believe it isn’t the sensor it’s the actual grill. The sensor doesn’t sit snug and it’s also a bit cockeyed which causes false alarms. It’s a bad grill mold.
Old 10-21-2018, 02:00 PM
htsunami's Avatar
what did you use to get the S5 Badge to stay seated in the grille?
Old 10-21-2018, 02:31 PM
arrtewwx's Avatar
We exchanged several emails/photos this week and even a video of it going off while sitting in traffic in downtown Dallas (was dry out, so wasn’t a water issue on the grille). A new replacement sensor is being mailed to me, which means the grille has to come back off. However, I need to go back to the shop that installed the grille and have them fix the crash bar paint job anyway - so going to have them swap it out. If it happens again, then would agree it’s likely a grille issue and something I’ll have to try to remediate or go back to the stock grille, if it is a major issue for me (sure hope not).
@Nikon1 - looks good! Hope you don’t have a sensor issue crop up this week
Quick Reply: EMD RS Grille/Front Parking Sensor Issue
