do C7 A6 cars have the 'after run' heater feature
Old 11-08-2018, 03:00 PM
awdinut's Avatar
Default do C7 A6 cars have the 'after run' heater feature
that the C6 A6s had where in the heater could be made to run for a period after the car was turned off ? If the C7s do have it, how is it engaged ?
Old 11-08-2018, 03:47 PM
raj99's Avatar
Have you opened your owners manual and read it?
If it's a standard feature, I bet it's documented
Old 11-08-2018, 10:42 PM
McFuzz's Avatar
If you are referring to the feature that allows the in-car HVAC to run after the car has shut off OR turn on x amount of minutes before you're about to leave for a trip - then it's a yes and no. Yes, it is possible to have it and no, it is not automatically available for USDM cars. You will need a VCDS cable to enable both the menu option in the MMI (via the Green Engineering Menu) and enable the "auxiliary heater" option via VAGCOM.
Old 11-09-2018, 01:38 AM
KevinGary's Avatar
it is a standard feature on US cars. I use mine all the time. I did not need to use vagcom to activate it.
Old 11-09-2018, 12:50 PM
McFuzz's Avatar
On your C7? I did not have that feature on my '14 TDI...
Old 11-09-2018, 01:42 PM
Tom B.'s Avatar
"REST" button. My car has one.
Old 11-09-2018, 03:11 PM
KevinGary's Avatar
i have it on the C7. It was also on my C6.
Old 11-09-2018, 03:33 PM
raj99's Avatar
I just learned something about my C6...must investigate
Old 11-09-2018, 04:19 PM
KevinGary's Avatar
It is one of the secret options! If I remember correctly you need to hold the fan button down for 2 seconds.
Old 11-09-2018, 04:28 PM
raj99's Avatar
thanks for that Kevin. Although I'm 99% certain I'll never use it, since I rarely if ever sit in the car after I've turned the car off and wait. I can see why others would use it, but it's nice to know these features exist even in cars that are almost 15 years old
Quick Reply: do C7 A6 cars have the 'after run' heater feature
