Underinflated tire pressure
Old 01-17-2019, 08:18 AM
grissoly's Avatar
Default Underinflated tire pressure
My 2011 A8L had this message about low tire pressure and it shows the left front tire. I seen this message before so could the wheel be bent.
Old 01-17-2019, 08:29 AM
Jibsymalone's Avatar
Did you check the pressure at your left front wheel?
Old 01-17-2019, 09:10 AM
grissoly's Avatar
28 psi. I had Pirelli P Zeros put on last year and they have Nitrogen air in them.
Old 01-17-2019, 09:30 AM
RED HORSE's Avatar
What car? 28 lbs sounds very low to me. I would expect a recommendation of at least 10 lbs more. You also need to realize that the majority of the air you breath is already nitrogen, so having nitrogen filled tires does not eliminate the need to periodically check the pressures.
Old 01-17-2019, 10:31 AM
grissoly's Avatar
2011 Audi A8L.
Old 01-17-2019, 04:20 PM
andrewmr's Avatar
Check the door jam (drivers door) and get the correct tire pressure and inflate to that PSI.
Then reset the TPMS in MMI.
Old 01-18-2019, 12:26 AM
landjb4u's Avatar
Originally Posted by grissoly
2011 Audi A8L.
Check all four tires. The tpms warming comes in when the your pressure drops 10psi or more from what's stored in the car's memory . Then check the owner's manual for the recommended psi and set that them accordingly.
Old 01-19-2019, 07:08 AM
Twglasgow's Avatar
check the owners manual for the correct tire pressure. The problem with relying on the door jamb has been discussed here.
jackhalley2010@yahoo.com
Audi Q8
12-05-2018 02:21 PM
njandy
A4 (B9 Platform) Discussion
19
08-09-2018 02:32 PM
Huria17
10
11-16-2017 06:26 PM
Xphstos
13
10-01-2009 10:28 AM
ctfalconk
Wheels & Tires Discussion
09-18-2007 01:46 PM
Quick Reply: Underinflated tire pressure
