First Q7 and Autel MS906BT
Old 02-12-2019, 05:37 PM
Dudeness30's Avatar
Default First Q7 and Autel MS906BT
I just got my first Audi, its a 2014 Q7 TDI Premium Plus with 23k miles. I have been learning all I can about it. I wanted to enable some features and such but don't use VCDS. I do have a Autel MaxiSys MS906BT and was trying it out tonight. I enabled the green menu in the MMI but did not change anything there yet. I also added 128 to the coding of the comfort settings to enable the windows up/dn from remote. I then went to channel 61 and changed it from 10 to 15 to give the options of windows and sunroof to open and close. It all worked perfectly. I am happy to see that the tool I have looks like it will do a lot on Audi.
I found another option listed called "adaptive motorway function" under "Highway Light". It is currently set as "not active". Anyone know what this is?
I also installed a brake controller and plan to try towing in a few days following the rules in the Audi manual with no WD bars, but with friction sway and electronic sway unit on trailer.
Anyway, I am new here and new to Audi's and having fun.
Old 02-15-2019, 02:11 PM
Dudeness30's Avatar
So today I replaced the battery with a Audi battery and recoded using my ms906bt and it was easy. Has code helper and drop down list to select battery brand. Then I enable the gear indicator to show on dash. Was just a toggle. Just wanted to share.
Old 02-16-2019, 03:56 AM
suicidalguitar's Avatar
That option will make your high beams aim more towards the middle of the road above a certain speed (highway speed). Can't remember exaclty which speed. But I have that option enabled and it works....
Old 02-16-2019, 04:14 PM
Built4Sin's Avatar
70+ I believe, you'll see your lights shift once you hit the speed, like you flashed your hi beams. Then once you start to slow down, you'll see it switch again. Its the Tri-Xenon headlights that have that option.
Old 02-17-2019, 07:29 AM
Dudeness30's Avatar
Thanks, thats good info, I will try that.
chuckhowlett
11-04-2003 11:00 PM
NeedForMoreSpeed
09-26-2002 10:52 AM
shawn9766
09-09-2002 04:55 PM
Victor F
TT (Mk1) Discussion
05-31-2000 12:41 PM
Quick Reply: First Q7 and Autel MS906BT
