MMI Maps -maximum number of downloads?
I did not know there was a limit of two map packs to download so i started downloading them all and so now I have Alaska and another map but not others I needed pre-loaded. I go to select them to download them and it says I've reached the maximum number of map downloads (2). Is there a way to erase them and download the ones I want?
I did the two downloads through the MMI at first, and then I also went onto the website and downloaded the 10GB update file onto an SD card and installed it. The MMI system said that the update was finished and all seemed to be ok, but when I go into the map update section of the MMI, it still shows only the two maps I previously downloaded as the only ones checked... How can this system be so bad? Any suggestions?
Do do we know when the first full 2019 map will be available for download (right now it’s 2018/2019)?
I updated to 2018/19 two weeks ago. Then, I saw the 2019 update this past week.
I don't see anything in this system via the car that allows me to remove previously downloaded map files and select new ones. Anyone have advice without having to wipe my entire MMI?
MMI
Kfr.frederiksen
A4 (B8 Platform) Discussion
07-25-2017 01:04 AM
