programmable TPMS sensors?
Old 03-27-2019, 08:36 AM
johnd64's Avatar
Default programmable TPMS sensors?
I ordered the Autel universal sensors and I was wondering if it's anything that can be messed up on the car TPMS by the tire shop when programming these.
The tires are not mounted on the car and my plan was to just have them installed and set up by the shop and later I will use the change wheels option to have the car recognize them.
They told me they need the car to be there in case they have to force the TPMS to sync them.
Maybe I should just find one that does not need programming.
Old 03-27-2019, 09:20 AM
raj99's Avatar
If you ordered the correct sensor (i.e. 433MHz), then the only "setup" you need to do once they are installed, is by going into your MMI Menu and letting the vehicle know you've got new tires.
Just press the following buttons:
CAR > (Click on Tire Pressure Monitoring) > Store Current Tire Pressure > Done
Old 03-27-2019, 10:27 AM
johnd64's Avatar
I got the dual 315/433 Mhz so they need programming.
Old 03-27-2019, 11:16 AM
raj99's Avatar
I would have passed on the programmable sensors and just gotten the 433 to start with. Since, you'll need to program the sensor once they are mounted via the Autel tool. Does the tire shop you are using even have that tool?
Old 03-27-2019, 06:42 PM
johnd64's Avatar
They do since they also use them for whenever someone needs a replacement.
Old 03-27-2019, 07:14 PM
raj99's Avatar
So from their perspective they want to ensure that when the mount your wheels and your car leaves their shop everything is functioning as per design. Vs you coming back if they haven't tested everything on the car and taking up more cycles in their shop. TBH, if they've programmed them as 433 and set the tire pressure for all tires as the same, then you should be good.
Old 04-15-2019, 11:58 AM
johnd64's Avatar
Just a quick update:The Autel sensors seem to work fine .They were very reasonable priced.
Can't comment on durability yet.
Old 04-19-2019, 06:20 AM
Dino1147's Avatar
I just installed 4 new sensors. I clicked "change wheels" in MMI but no pressure or temps display. After a good while of driving I get a TPMS error on the dash. So I need to select "store current tire pressure"? I'll give that a shot.
Old 04-19-2019, 10:37 PM
johnd64's Avatar
That's not going to do it probably.Did you have yours programmed?
Mine were the dual 315/433 and after the tire shop programmed them I just used change wheels and they worked.
Old 04-24-2019, 04:19 PM
Dino1147's Avatar
No I erroneously assumed that I could program them with VCDS. Dangit...
johnd64
04-15-2015 11:51 AM
Egil A64.2s - S6
Canadian Discussion
10-30-2008 03:40 PM
Blue DevilS4
NorCal Discussion
03-22-2006 08:22 AM
vanish
Wheels & Tires Discussion
09-25-2002 06:32 AM
Quick Reply: programmable TPMS sensors?
