I need a new blower on my Q5 2012, right?
Hey guys,
Pretty much looking for confirmation of what I "think I know", isn't that an assumption?
And of course assumption is the the mother of all...
So just bought a beauty of a Q5 2012, only thing wrong with it up to now, is no air from the vents unless over 70mph
Fuse looks brand new, hehehehe, so guessing blower, blown?
Before I rip out the glove box and buy a replacement and all that,
VCDS read of module below, any further thoughts?
Kinda wondering if all faults are from the one part not working or if there's more in that department I should replace.
Thank you guys.
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01140620120597
Coding: 46112000
Shop #: WSC 06335 000 00000
VCID: 7AADF1224CD02857D09-802E
7 Faults Found:
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 13
Reset counter: 240
Mileage: 169364 km
Time Indication: 0
Date: 2018.08.23
Time: 19:33:13
Freeze Frame:
Temperature: 25.0°C
Speed: 0.0 km/h
Voltage: 0.00 V
Current: 0.000 A
Voltage: 13.80 V
01844 - Control Module for Fresh Air Blower (J126)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Mileage: 169364 km
Time Indication: 0
Date: 2018.08.23
Time: 19:33:24
Freeze Frame:
Temperature: 25.0°C
01187 - Rear Temperature Flap Positioning Motor (V137)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 210
Mileage: 169372 km
Time Indication: 0
Date: 2018.09.11
Time: 20:49:39
Freeze Frame:
Voltage: 12.30 V
Temperature: 22.0°C
Temperature: 20.0°C
Count: 10000
Count: 9698
Bin. Bits: 01000000
Bin. Bits: 00000111
Time: 5.00 s
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 11
Reset counter: 1
Mileage: 169393 km
Time Indication: 0
Date: 2018.10.18
Time: 11:12:30
Freeze Frame:
Temperature: 16.0°C
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 3
Fault Frequency: 81
Reset counter: 216
Mileage: 169387 km
Time Indication: 0
Date: 2018.10.02
Time: 10:26:54
Freeze Frame:
Temperature: 28.0°C
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Voltage: 11.40 V
00714 - Centre Right Vent Positioning Motor (V111)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 251
Mileage: 169396 km
Time Indication: 0
Date: 2018.11.08
Time: 11:57:41
Freeze Frame:
Voltage: 14.40 V
Temperature: 15.0°C
Temperature: 13.0°C
Count: 14221
Count: 25000
Bin. Bits: 00000000
Bin. Bits: 10000001
Time: 196.00 s
01274 - Air Flow Flap Positioning Motor (V71)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 169424 km
Time Indication: 0
Date: 2019.03.19
Time: 15:57:53
Freeze Frame:
Voltage: 14.40 V
Temperature: 22.0°C
Temperature: 9.0°C
Count: 11947
Count: 12605
Bin. Bits: 01000000
Bin. Bits: 00001011
Time: 225.00 s
Thank you guys.
Coding: 46112000
7 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 240
Mileage: 169364 km
Time Indication: 0
Date: 2018.08.23
Time: 19:33:13
Freeze Frame:
Temperature: 25.0°C
Speed: 0.0 km/h
Voltage: 0.00 V
Current: 0.000 A
Voltage: 13.80 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Mileage: 169364 km
Time Indication: 0
Date: 2018.08.23
Time: 19:33:24
Freeze Frame:
Temperature: 25.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 210
Mileage: 169372 km
Time Indication: 0
Date: 2018.09.11
Time: 20:49:39
Freeze Frame:
Voltage: 12.30 V
Temperature: 22.0°C
Temperature: 20.0°C
Count: 10000
Count: 9698
Bin. Bits: 01000000
Bin. Bits: 00000111
Time: 5.00 s
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 1
Mileage: 169393 km
Time Indication: 0
Date: 2018.10.18
Time: 11:12:30
Freeze Frame:
Temperature: 16.0°C
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 81
Reset counter: 216
Mileage: 169387 km
Time Indication: 0
Date: 2018.10.02
Time: 10:26:54
Freeze Frame:
Temperature: 28.0°C
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Voltage: 11.40 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 251
Mileage: 169396 km
Time Indication: 0
Date: 2018.11.08
Time: 11:57:41
Freeze Frame:
Voltage: 14.40 V
Temperature: 15.0°C
Temperature: 13.0°C
Count: 14221
Count: 25000
Bin. Bits: 00000000
Bin. Bits: 10000001
Time: 196.00 s
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 169424 km
Time Indication: 0
Date: 2019.03.19
Time: 15:57:53
Freeze Frame:
Voltage: 14.40 V
Temperature: 22.0°C
Temperature: 9.0°C
Count: 11947
Count: 12605
Bin. Bits: 01000000
Bin. Bits: 00001011
Time: 225.00 s
15(estimate) screws removed.
Glove compartment dropped.
Remove light connector.
Remove Iphone connector, from inside first.
2 connectors on controller removed. (one comes from the "car" one goes to fan)
2 Silver T-type silver screws removed.
Controller then fell out.
1 more T-type silver screw out.
1 T-type black screw out.
Fan turned counterclockwise.
Fan dropped out.
{Hardest part}
Remove plastic casing of the fan motor.
Blow air in. Blow WD Electrical Cleaner in.
Some WD40 on the pivot at the top, or bottom depends on your point of view
Reverse the whole process.
Profit!
Or actually prevention of loss
Fan dropped out.
{Hardest part}
Profit!
You saved a ton of $$$. We had our '11 A4 motor replaced last fall. 😑
[QUOTE=sitsky;25306037]
{Hardest part}
any tips on how to remove the casing? The 2 metal clips on the top are super easy... but I’m having a hard time with the 2 plastic tabs on the sides... and I don’t want to ruin the casing.
thanks in advance!
{Hardest part}
thanks in advance!
