Why does my map revert back to standard from satellite?
Just picked up a 2019 Q7 as a kid hauler for my wife. Have noticed some quirks lately, namely that the map will randomly revert back to standard from satellite. I have to go into the menu and re-select satellite and then it flips over fine. Sometimes it stays...other times I start the car and it has gone back to standard. Anyone know if I am missing something??
Thanks,
Kent
Thanks,
Kent
Happens on both my 2018s as well, along with the overhead camera shift to graphic. I've just chalked it up to Audi and moved on. Maybe a software update needed, but I assume your 2019 already has the latest. Reliable high tech programming does not seem to be a core strength of Audi.
Considering I reboot my MS 10 operating system a half dozen times a week, truth. Maybe the systems have just gotten too complex, but I will say this about other software in other cars I've owned - whatever didn't work, uniformly didn't work when I tried that feature, and usually there was a fix somewhere along the line. In the Audis, what doesn't work seems to be variable, sometimes yes, sometimes no, sometimes maybe, and never a fix announced. Maybe the phase of the moon. Perhaps would be better if they followed the stopped watch analogy - at least it's right twice a day. So whatever is broken (let's use the backup camera for example), just make it permanently broken until they find a fix, if ever. Should be easy to program "broken" - the in-car manual in the Q7 being a good example: it just says "download manual" in MMI and never actually does it; I don't need to revisit that option, I know it will never work. That way, I won't have to wonder, like a box of chocolates, what I'm gonna get when I push a button...
Thanks,
Kent
Thanks,
Kent
I know when I had Audi connect there were times when it would not connect right away. I dropped the service since it will not pay $499 for 18 months for real time traffic info which is basically the only Audi connect service I used.
Just a thought. Google Earth map requires an internet connect through your Audi Connect subscription. If the car does not make a timely connection the map function may think the service is not available and default to the standard map. Another option is that the Audi Connect server (in the cloud) may have an issue with the google earth function so you car will not have the ability to show google maps.
Thanks,
Kent
Thanks,
Kent
Bob
I've had the same problem since I got my SQ5 in February. I've asked both my stores in Tampa and Miami and they have different answers. One technologist said Audi servers goes down often and when that happens it kicks you out, but you can switch it back. A different technologist told me that should not be happening and verified my Audi account subscription to make sure it was active. It was and he said if it did it again bring it to service to see if there was an update. I brought the issue to my advisor and she also said it shouldn't be doing it and she'd get back with me to see if there was an update or if she could get any more info. Didn't hear back from her. So, I've been just leaving it on standard maps. It's annoying to keep switching it over. Next time I'm there I'll bring it up again and see if there's an update on the issue. If it doesn't stay on satellite maps, there's barely a reason for me to keep my subscription when the time comes to buy... Love the rest of the car, though
Bob
Bob
in my S5 sportback and prior 2018 Q7 prestige this happened as well. the recent mmi software update seems to have fixed it. version 1316. sometimes it helps to search the forums to find fixes rather than accept substandard electronics in vehicles this expensive.
