Clanking sound from undercarrige
Q7 2009 with 110k miles. I can hear a single metal "clank" when I drive over a bump or hit a hole in the road; I think it happens mostly at low speeds but I could be wrong. I can only hear it when I have the front windows open and near a side wall(building or cars parked) so the sound can bounce. It sounds like a pipe that is loose in the clamp. I also have an occasional error code about the EVAP system that shows up once and a while and then disappears; no idea if it is related. Happens on all tires. I've been to two mechanics that couldn't find the source. One of them said that he thinks it is the struts; all of them failing at the same time? Any ideas guys?
I took it to a third guy and he couldn't find a problem with the undercarriage. The definitely hear the clang only at low speeds; I drove with the windows down near the divider on the highway and couldn't hear the clang. Does that mean a problem with the suspension? The car has been driven mostly in NY and NJ; the roads are terrible around here.
The problem could be the tie rods. I had the same problem on my C350. Here is what I would do. Jack up the front and the vehicle and check the front wheels by grabbing the wheel at 3 and 9 o'clock and push and pull on it to see if you feel any play. And then do the same thing to the rear.
Here is a good Youtube video.
Center bearing on driveshaft, get under the vehicle.. its right in the middle of the vehicle.. give it a good shake and see how much it moves, its a common failure.
GewoonIsmail
Q7 MK 1 Discussion
08-31-2017 12:39 PM
mikdivad
04-24-2000 06:20 AM
