Time to start retrofits. Factor Rear entertainment location?
Does anyone know where the factory Audi rear entertainment dvd drive is located? Going to retrofit this along with lane assist and night vision
Has anyone done these retrofits before? I use to do tons of retrofits for Mercedes. Did a few to my 2007 A8. Does anyone make the lane assist harness for this car or will I have to custom make it? Windshield is chipped anyway so I’ll get it replaced. Coding seems to be straightforward. Anyone done the adaptive cruise before? Car already has heads up display. Any other options I’m missing other than the ones discussed?
I agree that a forum is the best location to seek for info.
You know that people spent a lot of time digging into technical documentations, trials and errors, various costly failure before eventually making things work.
We are more than open, at least me, to share but there is still a minimum.
You might also know that companies are living from this, charging huge amount of money to retrofit the features you are asking.
Maybe you should learn first to say hello, please, thank you and bye?
Than we might consider helping you...
Not that I'm anything around here - but like you I have extensive retrofitting experience, but on BMW. There isn't an OEM feature I can't install/wire/code with NCSExpert/WinKFP or E-Sys. In the Audi world, I'm lucky if I can use my Ross-Tech cable to enable needle sweep on my gauge cluster. If you can do Mercedes retrofits as you say, and have mastered SCN coding, I'm sure Audi will be a breeze.
Just like with Mercedes, I'd start with the ETK and get all necessary parts, connectors and diagrams and get everything wired up. Share that info on the forum and then ask about coding. I'm positive someone will walk you through it. There seem to be some pretty sharp Audi experts here.
Not that I'm anything around here - but like you I have extensive retrofitting experience, but on BMW. There isn't an OEM feature I can't install/wire/code with NCSExpert or E-Sys. In the Audi world, I'm lucky if I can use my Ross-Tech cable to enable needle sweep on my gauge cluster. If you can do Mercedes retrofits as you say, and have mastered SCN coding, I'm sure Audi will be a breeze.
Waggin
Audi A5 / S5 / RS5 Coupe & Cabrio (B9)
03-12-2018 09:02 AM
LCP
21
04-22-2003 01:13 PM
