Airbag and seatbelt light (front passenger) randomly comes on/off
Airbag and seatbelt light (front passenger) randomly comes on/off with and without a front passenger present. Sometimes it happens sometimes it doesn’t. Driving a 2017 A4. Any ideas? Simple fix using the vag tool or something? Thanks.
https://static.nhtsa.gov/odi/tsbs/20...50667-9999.pdf
https://static.nhtsa.gov/odi/tsbs/20...49138-9999.pdf
Go here for the rest of the TSB’s for your car (there are more for the airbag/seatbelt): https://www.nhtsa.gov/vehicle/2017/A...Communications
Probably not related, but if I put my iPad directly on the passenger seat, I get the seatbelt warning light going off. Doesn't happen if I put my messenger bag (with the iPad in it) on the seat. I think it has to do with the magnetic cover, but it isn't the weight.
I’ve got a 2019 and will test with my iPad and magnetic cover shortly.
If it happens with absolutely nothing in the seat, then I'd guess an intermittent connection somewhere that's being toggled by bumps in the road or something similar.
I had a problem with the passenger airbag light would never go on, and sometimes my overhead lights would come on and flicker. All with no one in the passenger seat, but my sunroof still worked.
When to dealer they replace the control module in the overhead light console, replace the airbag light indicator.
Works good now, mine had nothing to do with the sensor in the passenger seat.
That's sometimes the problem with electrical issues and the web of systems - things are so interconnected that symptoms and causes can be wildly divergent. I now know that when my daughter's RX350 has a "Check AWD System" warning and the traction control is disabled, it means she didn't tighten the gas cap or overfilled the gas tank.
If it's under warranty, dealer diagnostics can usually dig into what's really going on.
