Front Console Lid Operation
I can’t recall this from when I picked up my car a few weeks ago, but I noticed today the center console lid does not stay open unless held in place. Otherwise after a few seconds it has a tendency to slam back down on its own and close. Is this normal operation? In my previous cars over the years, the kid usually stayed open without any additional interference.
I think he is talking about the armrest that covers the storage cubby. He's partially right - in previous cars it was a ratcheting mechanism that had a couple of heights it would lock in at. In the 2019 it only has one position that will lock and if you don't hit it in the right spot, it will close back down on you.
Yes that center storage is a total fail - not enough room and the armrest isn't adjustable
Otherwise great car
Otherwise great car
Correct, the adjustable sliding lid attached to the covered center console (with room for nothing more than a charging cell phone.)
I’ll test it later to see if I’m not pushing the lid further enough open to hold in place.
Otherwise great car
Otherwise great car
Manual would suggets it is adjustable in steps (at least here in the UK) will try when I go tot the car later. maybe you don;t have the "adjustable arm rest option"
No the sliding feature works fine.
The issue (?) that I've been noticing is when I open the lid vertically, it does not stay open unless held in place. If I let go of the lid at what I think to be the fully open position, the lid more or less falls and slams shut. Not a huge deal since I really only open and close the lid to place my phone in the charger, but the nature of the lid operation does not seem entirely normal. I will check later to confirm if I'm not pushing the lid up far enough. Although I obviously don't want to put too much stress on the lid in the open position and potentially break it.
I'll have to try again. Thus far, I've only mastered the locking of the lid in place an inch or so from closed. Any other position, including fully open, it continues to slam closed at full force. It's not enough of an issue for me to take it in, so I'll have the dealer look at it when I take it in for its first complimentary service down the line.
The center lid is supposed to stay open and adjustable to whatever height you set it at. It’s a little tricky getting the technique down on my car, but it works. You can even open the lid all the way vertical and it stays in place. To lock in the desired position you want: open the lid to roughly the height you want, then push down (slightly but quickly) to lock it in position. I use this feature a lot (since I have short arms) and like to lock it in place about 3-4 inches higher than closed position. One cautionary note: be extra careful when extending the arm slide forward, as the hard plastic underside can scratch the nice wood trim. I noticed my wood trim now has two etched lines from the lid slider. Not huge scratches, but it’s noticeable up close.
QuattroFan02
08-27-2008 11:13 AM
arekahtek2b
03-29-2004 06:12 PM
