Keyless Entry Not Working; Seeking Advice
Good afternoon all.
Since this Forum has been a wealth of knowledge and a great help on a couple of ”issues” [re] my 2009 V10 S8/D3 - an amazing and fun car (maybe my favorite car I’ve ever owned) - I thought I would seek help [re] the keyless entry. I believe it was working when I first acquired the car - I was away on vacation when it was delivered to my friends at Scarborough Jaguar/Land Rover - but hasn’t worked, even once, since. (They did install a new battery, for what that’s worth, although I’m not sure that has anything to do with it). I am able to start the car without using the key [in the ignition] but none of the doors will open or lock without my using the lock/unlock function on the key fob.
I would prefer not having to go to the Audi dealer if I don’t have to and my Jaguar dealership doesn’t have the [Audi] diagnostic tools to see what is wrong.
I’ve been reading about buying a VCDS (or whatever the diagnostic tool is called; sorry for my ignorance) and wondering if it makes sense to purchase one? Any other ideas about how to see what’s what?
Thank you,
RJ52
Thank you,
RJ52
Thanks again!
Jay
P.S. Scott. I told one of my mechanic friends I just ordered this and this was one of his “concerns”:
I honestly dont know Jay. I hope it does (being able to read various codes, including KESSY). But I dont know which network the code will be under and what the fault would describe as the problem with which part of the car. And then if we have to reset and program something we replace and are not able to then the vehicle might fault out. It's very tricky when the right tools are not used especially for the security part of the car.
So....my not being a mechanic myself, will purchasing the Ross-Tech help me solving this or any problem?
It will help immensely. Most report it paying for itself shortly after purchasing. Among other things, it's invaluable in keeping mechanics honest. Here's just one example from my experience. I had a CAN gateway lost redundancy code - this did not show up as a MIL or have any other symptom. It indicates that one of the redundant CAN bus loops was broken and should the other one fail, the car would be dead in the water. Using VCDS, I was able to troubleshoot it to the passenger side seat controller. The car was under extended warranty, so I took it to AUDI Chattanooga, who first said the code was immaterial and when I pressed them recommended replacing CAN bus wiring and modules. When I insisted it was the seat controller they eventually relented and confirmed my analysis. Ultimately, I got it fixed under my extended warranty for the cost of the deductible. Without VCDS, I would never known I was driving around with the car having no fault tolerance and even had I seen that would have been unsuccessful getting it fixed. Shortly before the warranty expired, I scanned and found a bunch of codes that I got fixed.
You know, there's a VAG-COM forum right here on AudiWorld. Check it out and see how ppl are using the tool!
Idiot’s Guide to Using VCDS???
Not to sound lazy - which I am not - but I just received my Ross-Tech device (thanks again Scott) and have successfully downloaded the program on my computer. Now what? (I actually did plug it into my vehicle - 2009 Audi S8/V10 - and hit “test” to make sure the connection was working, and it was, BUT after I saw the drop-down menu listing all the various cars listed I wasn’t sure what to do next (or what to check first...or all...for faults). I also wasn’t sure whether the car should be running or what? Is there an video anywhere directing me, the idiot/novice, what to do, etc.?
Thank you!
Thank you!
Here's Te Tour
Thank you!
Thank you!
https://www.ross-tech.com/vcds/tour/main_screen.php
Wednesday,19,June,2019,17:13:28:52400
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.0.6 HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUPN94E59N006142 License Plate: 09S8
Mileage: 154940km-96275mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 28 34 36
37 38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN94E59N006142 Mileage: 154940km-96275miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BSM) Labels: Redir Fail!
Part No SW: 4E0 910 552 K HW: 4E0 907 552 A
Component: 5.2L V10/4V FSI Ŗ0020
Revision: 5IH03--- Serial number: AUX3Z0H7756581
Coding: 01060009190F0160
Shop #: WSC 02313 785 00200
VCID: 2A0D02AF70F3E257B41-807E
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H04--- Serial number: 0127929
Coding: 0000002
VCID: 2411EC9712D734278ED-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 K HW: 4E0 614 517 CR
Component: ESP 5.7 allrad H50 0650
Coding: 0001627
Shop #: WSC 07322 000 00000
VCID: 2B0307AB7F09FB5F4F7-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H7756581
Coding: 0410624
VCID: 58E988671E1FA0C7D25-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 19
Mileage: 152016 km
Time Indication: 0
Date: 2019.04.18
Time: 14:28:40
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348HK087531001
Coding: 0000003
VCID: 33331FCBA739A39F077-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000072842
Subsystem 3 - Serial number: 0127.08.080000000100010120˙
Subsystem 4 - Serial number: 010120˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000154269
Coding: 0041297
VCID: 1C61D4772AA70CE736D-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133123
VCID: 382928E7BE5F40C7325-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 93
Time Indication: 0
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
Shop #: WSC 02399 823 56573
VCID: 2B0307AB7309FB5F4F7-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0375184
Coding: 0000100
VCID: 313F15C35D25918F75B-8064
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 62
Mileage: 152020 km
Time Indication: 0
Date: 2019.04.18
Time: 14:28:44
Address 11: Engine II Labels: Redir Fail!
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV000412A
Coding: 0532707
VCID: 290FFDA375F5E94FBDB-807C
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 038AJ
Subsystem 3 - Serial number: 0001.01.0000H0200000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB403F462ACU˙†63
Subsystem 5 - Serial number: 462ACU˙†63428RB403F4632AM˙†63
Subsystem 6 - Serial number: 4632AM˙†63528RB403F48C9B%˙†63
Subsystem 7 - Serial number: 48C9B%˙†63628RB403F4630AM˙†63
Subsystem 8 - Serial number: 4630AM˙†63729RB403F25C73U˙†63
Subsystem 9 - Serial number: 25C73U˙†63829RB403F25CC1Y˙
Subsystem 10 - Serial number: 25CC1Y˙
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90055082050003
Coding: 0012141
VCID: 2615F69F64EBC637909-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 N HW: 4E0 920 951 N
Component: KOMBIINSTR. VDO H83 0640
Revision: D04 Serial number: AUDID3H6100004
Coding: 0048283
Shop #: WSC 29140 001 1048576
VCID: 303910C7562F98877A5-8064
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0071
Revision: 00H06000 Serial number: 1100B0870584F7
Coding: F5F5DFFF707A0E00
VCID: 2D0709B3411DF56F513-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8524758
Shop #: WSC 00000 000 00000
VCID: 1A6DD26F209372D7241-804E
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 56
Mileage: 154901 km
Time Indication: 0
Date: 2019.06.14
Time: 13:38:38
Freeze Frame:
Text: 00000000
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 C
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000075564
Coding: 0000000
VCID: 619FA5834D45610FA5B-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015510
VCID: 2C0104B77A07FC6746D-8078
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
5 Faults Found:
01974 - Backrest/Head Adjustment Sensor (G376)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 6
Reset counter: 58
Mileage: 139164 km
Time Indication: 0
Date: 2018.05.25
Time: 08:05:37
01456 - Driver's Seat Switch for Seatback Adjust (E96); Back
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
01455 - Driver's Seat Switch for Seatback Adjust (E96); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
01450 - Switch for Driver Seat; Tilt Adjust; (E222); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 93
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
01449 - Switch for Driver Seat; Tilt Adjust (E222); Back
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 93
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395HW087521471
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000819800073
Coding: 0003477
VCID: 1D67D97331BD05EFC13-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 2019E08706CF2807EA5-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H11 0040
Revision: 00400011 Serial number: W040808180260
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 75
Mileage: 153227 km
Time Indication: 0
Date: 2019.05.11
Time: 11:06:23
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 22S00002 Serial number: 01106080013625
Coding: 0000026
VCID: 270BFB9B63E1DF3FABF-8072
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 01604080009897
Subsystem 3 - Serial number: 0216.04.080000000100030031˙
Subsystem 4 - Serial number: 030031˙
1 Fault Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 18
Reset counter: 140
Mileage: 154720 km
Time Indication: 0
Date: 2019.06.07
Time: 07:22:41
Freeze Frame:
Voltage: 12.70 V
Temperature: 15.0°C
Bin. Bits: 00000001
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000013215
Coding: 0010111
VCID: 1E65DE7F3CBB1EF7D89-804A
Subsystem 1 - Part No: 8K0 907 410 B
Component: HOMELINK H01 0010
Subsystem 2 - Serial number: 1770884T098901
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 57
Mileage: 154896 km
Time Indication: 0
Date: 2019.06.14
Time: 15:02:34
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000732
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 698FBDA3B575294F7DB-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352H0087659459
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000014239
Shop #: WSC 05927 444 59322
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 370711B1UI
Coding: 344530393135313035412056413033373037313142315549
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 54
Mileage: 151376 km
Time Indication: 0
Date: 2019.03.11
Time: 14:15:08
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000600057239
Coding: 0232428
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000808070208
Shop #: WSC 12336 024 394758
VCID: 34311CD7A237A4A71ED-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J87107Y
Coding: 1121402
VCID: 5CE194776A274CE7F6D-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 88
Mileage: 154544 km
Time Indication: 0
Date: 2019.05.24
Time: 15:39:60
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 D HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0050
Revision: 00H12000 Serial number: 08740819200297
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005055261
Coding: 0010900
VCID: 2809F8A76EFFD047A25-807C
End----------(Elapsed Time: 02:23, VBatt start/end: 14.0V/14.1V)-----------
www.Ross-Tech.com
Coding: 0000002
Coding: 0001627
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 19
Mileage: 152016 km
Time Indication: 0
Date: 2019.04.18
Time: 14:28:40
Coding: 4071520
Coding: 0000003
Coding: 0041297
Coding: 0133123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 93
Time Indication: 0
Revision: 00000000
Coding: 020000
Coding: 0000100
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 62
Mileage: 152020 km
Time Indication: 0
Date: 2019.04.18
Time: 14:28:44
Coding: 0532707
Coding: 0012141
Coding: 0048283
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 56
Mileage: 154901 km
Time Indication: 0
Date: 2019.06.14
Time: 13:38:38
Freeze Frame:
Text: 00000000
Coding: 0000000
Coding: 0015510
Coding: 4071530
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 58
Mileage: 139164 km
Time Indication: 0
Date: 2018.05.25
Time: 08:05:37
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 93
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 93
Mileage: 152268 km
Time Indication: 0
Date: 2019.05.03
Time: 09:16:38
Coding: 0003477
Coding: 0032364
Coding: 0048686
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 75
Mileage: 153227 km
Time Indication: 0
Date: 2019.05.11
Time: 11:06:23
Coding: 0000026
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 18
Reset counter: 140
Mileage: 154720 km
Time Indication: 0
Date: 2019.06.07
Time: 07:22:41
Freeze Frame:
Voltage: 12.70 V
Temperature: 15.0°C
Bin. Bits: 00000001
Coding: 0010111
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 57
Mileage: 154896 km
Time Indication: 0
Date: 2019.06.14
Time: 15:02:34
Revision: --H03---
Coding: 0000732
Coding: 0000018
Coding: 0000002
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 54
Mileage: 151376 km
Time Indication: 0
Date: 2019.03.11
Time: 14:15:08
Coding: 0232428
Coding: 1121402
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 88
Mileage: 154544 km
Time Indication: 0
Date: 2019.05.24
Time: 15:39:60
Coding: 0221208
Coding: 0010900
