Keyless entry stopped working? Fuse?
So out of the blue a week or so ago my keyless entry to my 2011 S4 stopped working. It's not the battery (won't work on either FOB).
Can use the key to unlock door and trunk by pressing the appropriate buttons, but won't automatically sense the key fob is near and open the doors.
Is there a Fuse for this I'm hoping that I can replace?
Is that the complete error? Or is there more to it which might give you a hint as to which sensor might be bad, like left or right, etc. Not sure if you googled the error, but I found this that might be helpful.
https://www.a5oc.com/threads/advance...problem.21211/
Don't automatically start blaming sensors and replacing them. Make certain your car battery is up to snuff. Yes, door key sensors are the first to shut down when battery is weak. Yes, you can start the car because the power management reserves all power to start the car but slowly shuts down other minor accessories. Worth charging/changing the battery before replacing sensors.
https://www.audiworld.com/forums/aud...anded-2971566/
Checked with my dealer, replaced my battery April 2017 at 113k km, have 150k km now so shouldn't be the issue. Will recheck my ODB error code when I get home as I don't think it saves the last error code in the app without running it again.
The following 2 users liked this post by pbcsd:
Evan's Santorin S4 (08-18-2019),
huskyz (08-17-2019)
